我认为这个问题已经被提到:HTTP//www. McCHIP.COM/FUMMS/M10338 70.ASPX.这里是一个详细的描述:昨天和几个月的时间,我使用IPE3.65,PIC
tiT3,PIC16F1459,用于LVP闪光灯;IPE3.65设置:选择:“使用低压编程模式条目”和“
电源目标
威廉希尔官方网站
”。工具“VDD集是3.3V PIC16F1459设置:LVP=布线:RA0/RA1为PGD/PGC,它们确实工作;今天我升级到IPE 4.10,设置都是相同的,包括硬布线,但4.10以下的错误报告:”MPLAB X已经检测到设备的低电压配置位设置为OFF,但工具是S。ET到低压编程,不能编程设备。纠正这个问题:1。改变工具的编程选项使用高压编程。2。改变设备的配置位以使用低电压(LVP= ON)。用高压编程装置重新编程设备的配置位。3。将工具的编程选项改回到低电压编程,用于设备的后续编程。“我通过RC0/RC1进行闪存,改变了工具的编程选项,使用高压编程;并保持PIC的LVP= ON;Flash已成功;但在返回B时仍然会得到相同的错误。ACK在低电压下运行,如3号所述。我担心IPE4.10错误地读取PIC16F1459的配置位,因为相同的设置在IPE3.65上工作;PIC的LVP被设置,但是IPE4.10读为OFF,为什么?PIC16F1459Rev=A6(1006)UZSLM
以上来自于百度翻译
以下为原文
I think this question has beed mentioned at:
http://www.microchip.com/forums/m1033870.aspx
here is a detailed description:
yesterday and for months time,i used IPE3.65,PicKit3,PIC16F1459,for LVP flashing;
IPE3.65 setting:
selected: "use low voltage programming mode entry" and "power target circuit from tool"
VDD set is 3.3V
PIC16F1459 setting:
LVP = ON
wiring:
RA0/RA1 as PGD/PGC
and they did work;
today i upgrated to IPE 4.10,settings are all the same include hard wiring,but 4.10 report below errors:
MPLAB X has detected that the device’s low voltage configuration bit is set to OFF but the tool is set to low voltage programming and cannot program the device. To correct this:
1. Change the tool’s programming option to use High Voltage programming.
2. Change the device’s configuration bit to use low voltage (LVP=ON). Program the device using high voltage to reprogram the device’s configuration bit.
3. Change the tool’s programming option back to Low Voltage programming for subsequent programming of the device.
i did flash via RC0/RC1 with Changing the tool’s programming option to use High Voltage programming;and keep PIC's LVP = ON;flash successeded;but still get the same error when return back operating at low voltage as mentioned at above No.3.
i am afraid that IPE4.10 is wrongly reading the PIC16F1459's configuration bits,since same settings worked on IPE3.65;PIC's LVP was set ON ,but IPE4.10 read as OFF,why?
pic16f1459. rev=a6(1006)
uzslm
