不幸的是,SCPI与GUI完全不匹配。
您正在寻找的命令被调用:DISP:WIND:TRAC:MEM - >此命令打开或关闭内存跟踪和DISP:WIND:TRAC:[STATe] - >此命令打开或关闭数据跟踪
一组SCPI命令显示如何设置跟踪并查看内存跟踪:SYST:FPR'清除所有跟踪和窗口DISP:WIND ON'创建窗口#1 CALC:PAR:DEF'myS11',S11'接下来的两行创建
一个S11测量,他们将其命名为“myS11”DISP:WIND:TRAC1:FEED'myS11'CALC:MATH:MEM'将跟踪副本存储为存储器DISP:WIND:TRAC1:MEM 1'打开存储器跟踪DISP
:WIND:TRAC1 OFF'关闭数据跟踪
以上来自于谷歌翻译
以下为原文
Unfortunately, the SCPI doesn't match the GUI exactly.
The commands that you are looking for are called:
DISP:WIND:TRAC:MEM -> this command turns on or off the memory trace
and
DISP:WIND:TRAC:[STATe] -> this command turns on or off the data trace
This set of SCPI commands shows how to setup a trace and view the memory trace:
SYST:FPR 'clears all traces and windows
DISP:WIND ON ' creates window #1
CALC:PAR:DEF 'myS11',S11 'The next two lines create an S11 measurement and they name it "myS11"
DISP:WIND:TRAC1:FEED 'myS11'
CALC:MATH:MEM ' Store off a copy of the trace as memory
DISP:WIND:TRAC1:MEM 1 ' Turn on the memory trace
DISP:WIND:TRAC1 OFF 'Turn off the data trace
不幸的是,SCPI与GUI完全不匹配。
以上来自于谷歌翻译
以下为原文
and
