电子发烧友william hill官网
喜
我一直在寻找一种使用MEMS麦克风估计声强的方法很长一段时间。我正在使用带有MEMS麦克风的STM32F4DISCOVERY板(它是MP45DT02)。我写了一个应用程序,使用这个麦克风接收声音,将其写入缓冲区并使用ST提供的库将其从PDM转换为PCM。到目前为止,它与ST给出的程序非常相似 - “音频播放和录音”。后来我使用快速傅立叶变换来获得信号频谱。 我需要估计声音的振幅如何反映在光谱的条高度上。数据表是适度的,甚至没有任何说明。我该如何解决这个问题? #mp45dt02-MEMS麦克风傅立叶 以上来自于谷歌翻译 以下为原文 hi, I've been looking for a way to estimate sound intensity using MEMS microphone for a very long time. I am using STM32F4DISCOVERY board with a MEMS microphone on it (it's MP45DT02). I wrote an application that receives sound using this this microphone, writes it into a buffer and converts it from PDM to PCM using library given by ST. So far it works very similar to a program given by ST - ''Audio playback and record''. Later I use fast fourier transform to get the signal spectrum. I need to estimate how the amplitude of the sound will be reflected on the spectrum's bars height. The datasheets are modest or even say nothing about it. How can I solve the problem? #mp45dt02-mems-microphone-fourier |
你好,先生,
为了理解数字音频输出和声音强度之间的关系,我建议在MEMS麦克风网页上阅读ST应用笔记AN4426: http://www.st.com/stonline/stappl/resourceSelector/app?page=fullResourceSelector&doctype=application_note&SubClassID=1564 问候, 亚历山德罗 以上来自于谷歌翻译 以下为原文 Hi Sir, in order to understand the realtion between the digital audio output and the sound intensity i would suggest to read the ST aplication note AN4426 at the MEMS microphone web page: http://www.st.com/stonline/stappl/resourceSelector/app?page=fullResourceSelector&doctype=application_note&SubClassID=1564 Regards, Alessandro |
喜
我是这个页面上的新手,但我需要一些帮助。 请即时工作STM32F4,我现在想要在船上编写带有microphono的代码。我想最终输出16位(PCM)。 还有办法吗? 谢谢 乔瓦尼 以上来自于谷歌翻译 以下为原文 hi, i am new on this page but i need some help. Please im working on STM32F4 and i want now to write an code with the microphono on board. I want to have finally an 16 bit on output(PCM). there is a way to do it? thanks giovani |
2738 浏览 1 评论
3241 浏览 1 评论
1810 浏览 1 评论
3650 浏览 6 评论
6039 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
353浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
444浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-25 12:55 , Processed in 0.954807 second(s), Total 80, Slave 64 queries .
