电子发烧友william hill官网
我有一台HP 8460p Elitebook,我正在尝试进行全新安装。
安装的大多数必需更新没有任何问题,除非两个重复失败,即使更新历史记录将它们列为已安装。 当我在“假定”安装后重新启动计算机时,它们默认返回失败状态。 你能告诉我可能导致这个问题的原因以及可以采取哪些措施来解决这个问题? 这两个更新是'基于Windows 10版本1079 x 64的系统累积更新KB8433832 x7和基于Windows 10版本1079 x 64的安全更新KBKB433932 x7。 谢谢。 CAG43 以上来自于谷歌翻译 以下为原文 I have an HP 8460p Elitebook that I am trying to do a clean install on. Most of the required updates installed with no problem except for two that keep failing repeatedly even though the update history lists them as installed. When I restart the computer after the "supposed" installation, they default back to having failed. Can you tell me what might be causing this problem and what can be done to solve it? The two updates are, 'The Cumulative Update For Windows 10 Version 1079 x 64 Based Systems KB8433832 x7 and the Security Update For Windows 10 Version 1079 x 64 Based Systems KBKB433932 x7. Thanks. CAG43 |
您需要与Microsoft联系以获取此问题的支持。
文件 以上来自于谷歌翻译 以下为原文 You need to contact Microsoft for support with this issue. Doc |
我会尝试一次安装一个...... 内容S 以上来自于谷歌翻译 以下为原文 I would try installing them one at a time... ...S |
522浏览 0评论
GMT+8, 2024-12-29 20:07 , Processed in 0.689851 second(s), Total 78, Slave 62 queries .
