大家好,
在我的NUC中有两个驱动器,一个是标准SATA SSD驱动器,另一个是金士顿NMVe驱动器。 SATA SSD驱动器作为驱动器1出现。我可以将其交换到驱动器0并使NVMe驱动器驱动器1? BIOS中是否有选项可以执行此操作? 谢谢, 史蒂夫 以上来自于谷歌翻译 以下为原文 Hello all, In my NUC are two drives, one a standard SATA SSD drive and the other is a Kingston NMVe drive. The SATA SSD drive comes up as Drive 1. Can I swap this to Drive 0 and make the NVMe drive Drive 1? Is there an option in the BIOS to do this? Thanks, Steve |
您实际上不需要此功能。
只需更改启动顺序(即将SSD置于启动顺序中的硬盘驱动器上方),您就可以开始使用了。 内容S 以上来自于谷歌翻译 以下为原文 You actually don't need this capability. Simply change the boot order (i.e. put the SSD above the HDD in the boot order) and you will be good to go. ...S |
521浏览 0评论
GMT+8, 2024-12-27 01:13 , Processed in 0.718180 second(s), Total 78, Slave 62 queries .
