我刚刚在2018年7月购买了这个桌面,一切正常,直到8/14/18我做了Windows更新,第二天当我使用我的PC时,我开始意识到我的蓝牙没有打开,我尝试打开但是按钮
失踪,然后我看起来更多,并弄清楚我的蓝牙驱动程序有错误。 请查看下面的图片了解更多信息。 您可以看到我在8/14/18 Windows更新后的8/15/18开始收到警告,我选择关闭并更新,因此更新后我的电脑直到8/15/18才开启。 我的电脑是Windows 10,我相信我的蓝牙来自我正在使用的网络适配器,这是 英特尔双频无线 - AC 3168 到目前为止,我已经从网上尝试了很多建议,但没有任何帮助。 到目前为止我尝试了什么: 1.将我的驱动程序更新到最新版本(已经是最新版本) 2.将我的电脑恢复到更早的位置 3.卸载Windows更新 4.转到service.msc重启蓝牙支持服务并将其设置为auto 5.卸载并重新安装驱动程序 6.使用Windows故障排除,蓝牙和硬件都没有解决问题 7.更改为通用蓝牙驱动程序(给我错误代码43,更新时它将我带回英特尔的最新版本,这就是我所拥有的) 8.和其他一些我忘了的东西,我尝试了很多东西而没有任何作用 如果有人有修复请帮忙! 微软请解决这个问题!!! 我买了200美元的无线耳塞只是为了无线而且之所以我买这台PC也是因为我想要蓝牙连接! 谢谢! 以上来自于谷歌翻译 以下为原文 I just bought this Desktop in July 2018 and everything works perfectly till 8/14/18 I did a Windows update, next day when I using my PC I start to realized my Bluetooth is not on, I try to turn it on but the button was missing and then I look more into it and figure out my Bluetooth driver is having a error. Please look at picture below for more info. You can see I start to get warnings on 8/15/18 after my Windows update on 8/14/18, I choose shut down and update so after update my PC didn't turn on till 8/15/18. My PC is Windows 10, I believe my Bluetooth comes from the Network Adaptor I'm using, which is Intel Dual Band Wireless - AC 3168 So far I have try a lot of suggestion from the web but nothing helps. What I tried so far: 1. Update my driver to the newest (it already on the newest) 2. restore my pc to a earlier point 3. uninstall windows update 4. go to service.msc restart Bluetooth support service and set it to auto 5. uninstall and reinstall driver 6. using windows troubleshooting, Bluetooth and hardware both didn't fix problem 7. Change to Generic Bluetooth driver (gives me error code 43, when update it brings me back to Intel's latest version, which is what I had) 8. and some other stuff I forgot, I had try so much things and nothing works If anyone has a fix please help! Microsoft please fix this!!! I Bought a $200 wireless Earbud just for wireless and the reason why I bought this PC it also because I want Bluetooth connection! Thanks!
3个回答
你好,wise1993。
非常感谢您与英特尔社区团队分享您的问题。 我将非常乐意为您提供帮助。通过检查您获得的错误代码(参见Windows中的设备管理器中的错误代码,错误代码10),似乎应该重新安装驱动程序。首先,请确保 在BIOS中启用蓝牙。 然后,让我们为驱动程序尝试一个干净的安装。 请按照以下步骤来实现: 1.下载并保存适配器的最新Windows®10驱动程序:1。蓝牙:https://downloadcenter.intel.com/download/28009/Intel-Wireless-Bluetooth-for-Windows-10?product = 94854 2。 无线网络连接:HTTPS://downloadcenter.intel.com/download/27989/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10产品= 948542? 在Apps& Windows *设置中的功能,卸载“英特尔®PROSet/无线软件”和“英特尔®无线蓝牙®”的任何实例。 出现提示时,选择“放弃设置”.3。 手动卸载驱动程序:1。Bluetooth®:转至设备管理器>Bluetooth®>右键单击您的英特尔(R)无线蓝牙(R)并将其卸载。 确保将选项标记为“删除此设备的驱动程序软件”。 2. WiFi:转到设备管理器>网络适配器>右键单击您的英特尔(R)双频无线-AC 7260并将其卸载。 确保将选项标记为“删除此设备的驱动程序软件”。 清除临时文件:按Windows *键+ R打开运行框。 键入Cleanmgr.exe,然后按确定。 在这里,您需要确保检查临时文件,您可以取消选中其他所有内容,然后按OK。 重新启动计算机。 安装先前在第一步中下载的驱动程序。 首先安装Bluetooth®软件包,然后安装无线驱动程序。与我们分享结果.Antony S. 以上来自于谷歌翻译 以下为原文 Hello, wise1993. Thank you very much for sharing your issue with the Intel Communities Team. I will be more than glad to assist you. By checking the error code that you are getting (cf.Error codes in Device Manager in Windows, error code 10), it seems that the drivers should be reinstalled. Firstly, please make sure that the Bluetooth is enabled in the BIOS. Then, let us try a clean installation for the drivers. Please follow these steps to achieve so: 1. Download and save the latest Windows® 10 drivers for your adapter: 1. Bluetooth: https://downloadcenter.intel.com/download/28009/Intel-Wireless-Bluetooth-for-Windows-10?product=94854 2. Wi-Fi: https://downloadcenter.intel.com/download/27989/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=94854 2. Under Apps & Features in Windows* Settings, uninstall any instance of the "Intel® PROSet/Wireless Software" and "Intel® Wireless Bluetooth®." When prompted, choose to "discard settings." 3. Manually uninstall your drivers: 1. Bluetooth®: Go to the Device Manager > Bluetooth® > Right click on your Intel(R) Wireless Bluetooth(R) and uninstall it. Make sure to mark the option to "Delete the driver software for this device." 2. WiFi: Go to the Device Manager > Network Adapters > Right click on your Intel(R) Dual Band Wireless-AC 7260 and uninstall it. Make sure to mark the option to "Delete the driver software for this device." 4. Clear out your temporary files: Press the Windows* Key + R to open the run box. Type Cleanmgr.exe and press OK. Here you will need to make sure Temporary Files are checked, you may uncheck everything else, then press OK. 5. Reboot your computer. 6. Install the drivers previously downloaded back in step one. Installing the Bluetooth® package first, followed by the wireless driver. Share with us the results. Antony S. |
您好,wise1993。我想仔细检查您是否能够执行我附加到上面帖子和结果的故障排除步骤.Antony S.
以上来自于谷歌翻译 以下为原文 Hello, wise1993. I would like to double check if you were able to perform the troubleshooting steps that I attached to the post above and the results. Antony S. |
我通过在电源设置时禁用快速启动来解决问题,然后我卸载了英特尔无线蓝牙驱动程序并关闭计算机,然后重新打开并win10自动安装驱动程序。 我做了完全相同的步骤,但没有禁用快速启动,它没有工作,但在我禁用快速启动后再次执行它的工作。 因此,我认为当快速启动启用时,它不会完全关闭计算机或其他东西,所以它不起作用。 感谢您的支持和时间 以上来自于谷歌翻译 以下为原文 I fix the problem by disabling fast startup at power setting and then I uninstalled the intel wireless Bluetooth driver and turn off the computer by shutting down and then turn it back on and win10 auto install the driver. I did the exact same steps but without disable fast startup and it didn't work, but after I disable fast startup and do the steps again it worked. So I think when fast startup is enable it don't completely shut down the computer or something so it didn't work. Thank you for your support and time |
528浏览 0评论
GMT+8, 2025-1-4 09:52 , Processed in 0.624098 second(s), Total 49, Slave 43 queries .
