我使用LIS3DH测量机器的振动,我知道mems加速度计通常不用于此应用,但是,我设置了高分辨率模式,这给了我150Hz的带宽。我设置了LIS3DH并将其数据与我所拥有的压电加速度计进行比较。我注意到,在低频(低于40Hz)下,两个加速度计的峰峰值非常相似。但当我超过那个(80-100赫兹)时,我开始看到LIS3DH p-p与另一个相比有所下降。 LIS3DH是否不适合此应用?
#lis3dh机 以上来自于谷歌翻译 以下为原文 I am using a LIS3DH to measure a machine's vibration, I understand that mems accelerometers are not usually used for this application, but nevertheless, I set up the acc to High resolution mode which gives me a bandwidth of 150Hz. I have the LIS3DH set up and comparing its data with a piezo accelerometer that I have. I noticed that at low frequency (under 40Hz) peak to peak values of both accelerometers are very similar. but when I go over that (80-100 Hz) I start to see a drop in the LIS3DH p-p compared to the other one. Is the LIS3DH just not suitable for this application ? #lis3dh-machine |
LIS3DH与压电传感器有什么区别?
以上来自于谷歌翻译 以下为原文 What is the difference between the LIS3DH and the piezo sensor? |
2762 浏览 1 评论
3248 浏览 1 评论
1820 浏览 1 评论
3663 浏览 6 评论
6055 浏览 21 评论
1346浏览 4评论
209浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
364浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
458浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
281浏览 2评论
GMT+8, 2025-1-4 10:08 , Processed in 1.046385 second(s), Total 75, Slave 59 queries .
