嗨,我想更换NUC6CAYH的rtc电池,但是当我打开NUC时,我找不到电池。
是否有文件描述更换rtc的程序? 提前致谢。 以上来自于谷歌翻译 以下为原文 Hi, I want to replace the rtc battery of a NUC6CAYH, but when I open the NUC, I cannot find the battery. Is there a document describing the procedure to replace the rtc? Thanks in advance. |
4个回答
1.更换CMOS电池的步骤:英特尔®NUC上的CMOS电池
2.电池位于威廉希尔官方网站 板上侧。 您需要从NUC案例中删除此板。 莱昂 以上来自于谷歌翻译 以下为原文 1. The procedure for CMOS battery replacement: CMOS Battery on the Intel® NUC 2. The battery is located on the board upper side. You need to remove this board from the NUCs case. Leon |
嘿莱昂 我的问题是:如何从机箱中取出威廉希尔官方网站 板? 我已经卸下了硬盘,两块螺丝用于安装威廉希尔官方网站 板, vga连接器和后部的小塑料盖(HDMI连接器等周围)。 我还删除了de塑料顶部机箱盖。 然后我可以移动一下板,但我还是无法移除它。 我还需要拆除或拧下什么? 以上来自于谷歌翻译 以下为原文 Hey Leon My problem is: howto remove the board from the chassis ? I have already removed the hard disk, two screws with which the board is attached, the vga connector and the little plastic cover(around the HDMI connector etc.) at the back. I also removed de plastic top chassis cover. Then I can move the board a bit, but I can not remove it yet. What else do I have to remove or unscrew? |
我没有像你这样的NUC。 但我建议在断开天线导线后拧下固定WiFi适配器并取下此适配器的螺丝。 请参阅此剪辑,了解如何在非常类似的NUC上执行此操作:英特尔NUC风扇替换 - YouTube 希望这会有所帮助 莱昂 以上来自于谷歌翻译 以下为原文 I don't have NUC like yours. But I suggest to unscrew the screw holding WiFi adapter and removing this adapter after disconnecting the antenna wires. Please see this clip showing how to do this on very similar NUC:Intel NUC Fan Replacement - YouTube Hope this will help Leon |
飞雪9366 发表于 2018-12-3 16:14 感谢您的提示,我设法删除了威廉希尔官方网站 板。 但电池似乎没问题。 我几乎可以肯定电池没电了,因为在短暂的断电后,时钟还可以,但是在断电后更长时间没有。 在bios中我发现:“CMOS TIME NOT SET 1/1/2016 0,0,0”。 测试是在没有操作系统的情况下完成的(因此没有连接磁盘)以确保问题不是来自操作系统。 我想我将不得不向william hill官网 提出一个新问题。 再次感谢,Marc 以上来自于谷歌翻译 以下为原文 Thanks to your tip, I managed to remove the board. However the battery appears okay. I was almost certain that the battery failed, because after a short power break, the clock was ok but not after a longer power break. In the bios I found: "CMOS TIME NOT SET 1/1/2016 0, 0, 0". Testing was done without an OS (thus no disk connected) to be sure that the problem did not come from the OS. I suppose I will have to ask a new question to the forum. Thanks again, Marc |
538浏览 0评论
GMT+8, 2025-1-13 19:42 , Processed in 0.647299 second(s), Total 81, Slave 65 queries .
