嗨,PIC10/PIC12/PIC16/PIC18版本是同一名称的外围图书馆的一部分;选择这些版本为您提供了通过简单设置视图直接设置外围设备的最佳细节的可能性。如果您希望完全控制配置过程(即,您有一个特定的设置来实现和/或来自该配置的约束),请使用这些版本。基础服务版本本质上更抽象,通常提供外围设备的基本功能以缓解CO。成形过程。如果你对外围设备及其能力了解不多,或者你只需要添加到应用程序中的功能。这两个都是附加的库,可以从MCC添加/更新/删除。下面是各个库的链接,以及每个版本的发布说明:HTTP://www. MyCHIP.COM/MPLAB/MPLAB-CODEL配置器
以上来自于百度翻译
以下为原文
Hi,
The
PIC10/PIC12/PIC16/PIC18 versions are part of the peripheral library with the same name; selecting these versions offers you the possibility to directly set up the peripheral in its finest details, via the Easy Setup view. Use these versions if you want complete control over the configuration process (i.e. you have a specific set-up to implement and/or constraints derived from that).
The
Foundation Services versions are more abstract in nature, typically offering the basic functionality of the peripheral easing the configuration process. Use this if you don't know much about the peripheral and its capabilities and/or you just need the functionality added to your application.
Both are add-on libraries you can add/update/remove from MCC. Here are links to individual libraries, along with Release notes for each:
http://www.microchip.com/mplab/mplab-code-configurator
以上来自于百度翻译
以下为原文
Hi,
The
The
