我正在使用c28085001散热器和旧cpu风扇进行激光二极管散热器组件的原型设计。
我需要知道组件的散热能力和尺寸,以便我知道我是否可以使用它。 数据表会很有帮助。 以上来自于谷歌翻译 以下为原文 I am using c28085001 heat sink with fan from an old cpu for prototyping heat sink assembly of laser diode. I need to know the thermal dissipation capacity and dimensions of the assembly so that i know if i Will be able to use it or not. A datasheet would be much helpful. |
你好aditisharma,
感谢您加入此英特尔社区。 我知道您希望获得有关带风扇的散热器散热能力的更多信息。 我想提供更多相关信息。 您已请求的此产品的交互式技术支持已停止。 在这种情况下,我们建议您访问以下社区和网站以获取社区成员的推荐。 停产产品社区。 https://communities.intel.com/community/tech/discontinued-products 已停产的产品 https://www.intel.com/content/www/us/en/support/discontinued-products.html 此外,您还可以查看可能包含有用信息的“散热设计指南”。 http://download.intel.com/design/intarch/designgd/27370403.pdf 万纳G. 以上来自于谷歌翻译 以下为原文 Hello aditisharma, Thank you for joining this Intel Community. I understand that you would like to get more information about the thermal heat dissipation capacity of a heat sink with fan. I would like to provide more information about this. The interactive technical support for this product you have requested has been discontinued. In this case, we recommend you to visit the following community and webiste to get recommendations from fellow community members. Community on Discontinued Products. https://communities.intel.com/community/tech/discontinued-products Discontinued Products https://www.intel.com/content/www/us/en/support/discontinued-products.html Additionally, you may also review this Thermal Design Guide that may contain useful information. http://download.intel.com/design/intarch/designgd/27370403.pdf Wanner G. |
GMT+8, 2025-3-7 10:52 , Processed in 0.656086 second(s), Total 75, Slave 59 queries .
