我使用viper22a设计了一个AC-DC转换器。拓扑是飞回来的。正如viper22a的数据表所述,Vds(st)应小于400V。所以我想知道当输入交流电压为300V时viper22a是否会损坏?那时,Vds(st)将是424V(300 * sqrt(2))。它超过了最大Vds(st)。 Vds(st)究竟是什么意思?
最后,我很抱歉我的英语不好。请某人给我一个明确的答案。谢谢。 #viperplus #viperplus 以上来自于谷歌翻译 以下为原文 i have designed a AC-DC converter by using viper22a. the topology is fly-back. as the viper22a's datasheet say, the Vds(st) should be less than 400V. so i want to know if the viper22a may be damaged when the input AC voltage is 300V ? at that time,Vds(st) would be 424V (300*sqrt(2)). it has excessed the maximum Vds(st). what on earth does the Vds(st) mean? at last ,i am sorry for my poor english. please *** give me a definitive answers. thanks. #viperplus #viperplus |
嗨,
Vds(st)是内部电流发生器可以维持的最大直流电压,用于操作VIPer22A的启动。因此,如果启动时漏极引脚上的电压超过400V,则VIPer22A无法正常启动,ST无法保证该器件。在开关模式下,VIPer22A的最大击穿电压为730V。 在这种情况下,我建议使用VIPer27L / H,它在启动和开关模式下都具有800V的击穿电压。 以上来自于谷歌翻译 以下为原文 Hi, Vds(st) is the maximum DC voltage that can be sustained by the internal current generator which operates the start-up of VIPer22A. So, if the voltage on the drain pin at start-up exceeds 400V, VIPer22A cannot start properly and ST does not guarantee the device. While in switching mode the maximum breakdown voltage of VIPer22A is 730V. In this case I suggest to use VIPer27L/H which features 800V as breakdown voltage, both at start-up and in switching mode. |
2741 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3653 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
203浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
356浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
446浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-26 22:43 , Processed in 1.202114 second(s), Total 48, Slave 42 queries .
