电子发烧友william hill官网
你好,
我已经阅读了SPC56EL70(e200z4)的核心手册。我想在SPC5Studio的configuration.xml中使用中断例程处理IVOR1异常。我不清楚我应该在ISR中写什么(什么号码?IVOR1在参考手册的INTC章节中没有出现) 非常感谢你 以上来自于谷歌翻译 以下为原文 Hello, I have read the core manual of SPC56EL70 (e200z4). I want to handle the IVOR1 exception with an interrupt routine in configuration.xml in SPC5Studio. It's not clear to me what I should write in the ISR in question (what number? IVOR1 is not present in INTC chapter in the reference manual) Thank you very much |
4个回答
你好Stefano,
你在谈论机器检查中断(IVOR1)吗? 或ivor1关于软件向量表? / *软件向量表。从IVOR4访问向量 仅处理程序。为了声明一个中断处理程序,只需创建 与矢量名称相同的函数,符号将 覆盖此处声明的弱符号。* / 已在OSAL组件中完成 1)用于IVOR1,(机器检查中断) 你应该更新ivor.s(使用补丁模式) 参见e200z4RM.pdf中的第5.7.2章 http://cache.nxp.com/files/32bit/doc/ref_manual/e200z4RM.pdf?fpsp=1&WT_TYPE=Reference%20Manuals&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation&fileExt=.pdf 2)用于ivor1(软件向量表)(来自IVOR4) 你检查了表473. INTC_0和INTC_1的中断源? 在RM0342中,它存在。 你应该通过OSAL组件启用 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Stefano , Are you talking about Machine Check Interrupt (IVOR1) or ivor1 about the software vector table ? /* Software vectors table. The vectors are accessed from the IVOR4 handler only. In order to declare an interrupt handler just create a function withe the same name of a vector, the symbol will override the weak symbol declared here.*/ Already done in OSAL components 1) for IVOR1, (Machine Check Interrupt) you should update ivor.s (using patch mode) cf chapter 5.7.2 in e200z4RM.pdf http://cache.nxp.com/files/32bit/doc/ref_manual/e200z4RM.pdf?fpsp=1&WT_TYPE=Reference%20Manuals&WT_VENDOR=FREESCALE&WT_FILE_FORMAT=pdf&WT_ASSET=Documentation&fileExt=.pdf 2) for ivor1 (software vector table) (from IVOR4) did you check Table 473. Interrupt sources for INTC_0 and INTC_1 ? in RM0342 , it is present. you should enable by OSAL component Best regards Erwan |
我在说第一个。
所以: 我可以写一个汇编例程,我必须在某些时候(我不确切地说)添加ivor.s: #if CORE_SUPPORTS_DECREMENTER / * * _IVOR1 * / .align 4 .globl _IVOR1 .type _IVOR1,@ function _IVOR1: / *创建外部堆栈帧(extctx结构)。* / stwu%sp,-80(%sp)/ * extctx结构的大小。* / #if PPC_USE_VLE&& CORE_SUPPORTS_VLE_MULTI e_stmvsrrw 8(%sp)/ *保存PC,MSR。 * / e_stmvsprw 16(%sp)/ *保存CR,LR,CTR,XER。 * / e_stmvgprw 32(%sp)/ *保存GPR0,GPR3 ...... GPR12。 * / #else / *!(PPC_USE_VLE&& CORE_SUPPORTS_VLE_MULTI)* / stw%r0,32(%sp)/ *保存GPR0。 * / mfSRR0%r0 stw%r0,8(%sp)/ *保存PC。 * / mfSRR1%r0 stw%r0,12(%sp)/ *保存MSR。 * / mfCR%r0 stw%r0,16(%sp)/ *保存CR。 * / mfLR%r0 stw%r0,20(%sp)/ *保存LR。 * / mfCTR%r0 stw%r0,24(%sp)/ *保存点击率。 * / mfXER%r0 stw%r0,28(%sp)/ *保存XER。 * / stw%r3,36(%sp)/ *保存GPR3 ...... GPR12。 * / stw%r4,40(%sp) stw%r5,44(%sp) stw%r6,48(%sp) stw%r7,52(%sp) stw%r8,56(%sp) stw%r9,60(%sp) stw%r10,64(%sp) stw%r11,68(%sp) stw%r12,72(%sp) #endif / *!(PPC_USE_VLE&& CORE_SUPPORTS_VLE_MULTI)* / / *例行执行* / b _ivor_exit #endif / * CORE_SUPPORTS_DECREMENTER * / 我错过了什么吗? 以上来自于谷歌翻译 以下为原文 I'm talking about the first one. So: I can just write an assembly routine, and I have to add at some point (I don't know exactly) of ivor.s: #if CORE_SUPPORTS_DECREMENTER /* * _IVOR1 */ .align 4 .globl _IVOR1 .type _IVOR1, @function _IVOR1: /* Creation of the external stack frame (extctx structure).*/ stwu %sp, -80(%sp) /* Size of the extctx structure.*/ #if PPC_USE_VLE && CORE_SUPPORTS_VLE_MULTI e_stmvsrrw 8(%sp) /* Saves PC, MSR. */ e_stmvsprw 16(%sp) /* Saves CR, LR, CTR, XER. */ e_stmvgprw 32(%sp) /* Saves GPR0, GPR3...GPR12. */ #else /* !(PPC_USE_VLE && CORE_SUPPORTS_VLE_MULTI) */ stw %r0, 32(%sp) /* Saves GPR0. */ mfSRR0 %r0 stw %r0, 8(%sp) /* Saves PC. */ mfSRR1 %r0 stw %r0, 12(%sp) /* Saves MSR. */ mfCR %r0 stw %r0, 16(%sp) /* Saves CR. */ mfLR %r0 stw %r0, 20(%sp) /* Saves LR. */ mfCTR %r0 stw %r0, 24(%sp) /* Saves CTR. */ mfXER %r0 stw %r0, 28(%sp) /* Saves XER. */ stw %r3, 36(%sp) /* Saves GPR3...GPR12. */ stw %r4, 40(%sp) stw %r5, 44(%sp) stw %r6, 48(%sp) stw %r7, 52(%sp) stw %r8, 56(%sp) stw %r9, 60(%sp) stw %r10, 64(%sp) stw %r11, 68(%sp) stw %r12, 72(%sp) #endif /* !(PPC_USE_VLE && CORE_SUPPORTS_VLE_MULTI) */ /*routine execution */ b _ivor_exit #endif /* CORE_SUPPORTS_DECREMENTER */ Do I miss something? |
你好Stefano,
我认为应该没问题。 你有什么方法可以产生IVOR1? 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Stefano , i think that it should be ok. What is your way to generate IVOR1 ? Best regards Erwan |
这是我正在努力的事情:我需要它来处理无法纠正的错误。我必须禁用ECSM报告,因为我不想在我的应用程序中重置DED,但是我没有任何机制来注入DED以避免重置:即使我只为注入启用ECSM报告,因为注入了错误同
SPP_MCM.EEGR.R = 0x0220; //取消注释这三行以注入无法纠正的错误 0x00014008:70 1F E7 F4 E_LIS R0,0xFFF4 0x0001400C:70 E0 02 20 E_LI R7,0x220 0x00014010:01 06 SE_MR R6,R0 0x00014012:5C E6 00 4A E_STH R7,0x4A(R6) *((uint32_t *)0x40002000)= PATTERN; 0x00014016:62 10 SE_BGENI R0,0x1 0x00014018:65 20 SE_BSETI R0,0x12 0x0001401A:70 EA E5 55 E_LIS R7,0x5555 0x0001401E:70 EA C5 55 E_OR2I R7,0x5555 0x00014022:01 06 SE_MR R6,R0 0x00014024:D0 76 SE_STW R7,0x0(R6) SPP_MCM.EEGR.R = 0x0000; 0x00014026:70 1F E7 F4 E_LIS R0,0xFFF4 0x0001402A:48 07 SE_LI R7,0x0 0x0001402C:01 06 SE_MR R6,R0 0x0001402E:5C E6 00 4A E_STH R7,0x4A(R6) 我执行了一次重置:0x00014016:62 10 SE_BGENI R0,0x1 这不是我期望的行为,因为在手册中写入ECC是根据文字计算并在读数时检查的。 以上来自于谷歌翻译 以下为原文 That's something I'm struggling with: I need it in order to handle uncorrectable errors. I must disable ECSM reporting because I don't want a reset on DED in my application, but I don't have any mechanism to inject a DED avoiding reset: even if I enable ECSM reporting just for the injection, as the error is injected with SPP_MCM.EEGR.R= 0x0220; //uncomment these three lines to inject uncorrectable error 0x00014008: 70 1F E7 F4 E_LIS R0,0xFFF4 0x0001400C: 70 E0 02 20 E_LI R7,0x220 0x00014010: 01 06 SE_MR R6,R0 0x00014012: 5C E6 00 4A E_STH R7,0x4A(R6) *((uint32_t *) 0x40002000) = PATTERN; 0x00014016: 62 10 SE_BGENI R0,0x1 0x00014018: 65 20 SE_BSETI R0,0x12 0x0001401A: 70 EA E5 55 E_LIS R7,0x5555 0x0001401E: 70 EA C5 55 E_OR2I R7,0x5555 0x00014022: 01 06 SE_MR R6,R0 0x00014024: D0 76 SE_STW R7,0x0(R6) SPP_MCM.EEGR.R= 0x0000; 0x00014026: 70 1F E7 F4 E_LIS R0,0xFFF4 0x0001402A: 48 07 SE_LI R7,0x0 0x0001402C: 01 06 SE_MR R6,R0 0x0001402E: 5C E6 00 4A E_STH R7,0x4A(R6) I have a reset on the execution of: 0x00014016: 62 10 SE_BGENI R0,0x1 This is not the behavior I expect, as on the manual is written that ECC is calculated on writings and checked at readings. |
2747 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3655 浏览 6 评论
6045 浏览 21 评论
1342浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
359浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
451浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
277浏览 2评论
GMT+8, 2024-12-30 02:38 , Processed in 1.189602 second(s), Total 81, Slave 65 queries .
