Hello@josh.onn,
您是否检查过这里提到的可能性:http://www.xilinx.com/support/answers/31866.html
问候,阿希什-----------------------------------------------
- - - - - - - - - - - - - - - - - - - - - - - -请注意-
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .--------------------
以上来自于谷歌翻译
以下为原文
Hello @josh.onn,
Did you check the possibilities mentioned here http://www.xilinx.com/support/answers/31866.html
Regards,
Ashish
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
Hello@josh.onn,
以上来自于谷歌翻译
以下为原文
Hello @josh.onn,
Regards,
Ashish
