None
以上来自于谷歌翻译
以下为原文
Thanks for the reply.
The IP are up to date. Do you think there any other issues?
One thing I observed is that when customizing the IP, I didn't see the tab for board, which is present in the figures shown in the documentation. Please find them in the attachments.
I was trying to use mipi_csi2_rx with IMX274 camera sensor. I instantiated the IP in vivado, did "generate output products", then tried to open the example design project, as I am unsure of all the connections to this IP block. Do you think there is a better way to use these IP's? The mipi_csi2_rx IP documentation is not clear on how to build example design.
report_ip_status
IP Status Summary
1. Project IP Status
Your project uses 12 IP. Some of these IP may have undergone changes in this release of the software. Please review the recommended actions.
More information on the Xilinx versioning policy is available at www.xilinx.com.
Project IP Instances
| Instance Name | Status | Recommendation | Change | IP Name | IP | New Version | New | Original Part |
| | | | Log | | Version | | License | |
| mipi_csi2_rx_subsystem_0 | Up-to-date | No changes required | *(1) | MIPI CSI-2 Rx | 3.0 | 3.0 | Purchased | xczu9eg-ffvb1156-2-e |
| | | | | Subsystem | | | | |
| bd_639e_0_phy_0 | Up-to-date | No changes required | *(2) | MIPI D-PHY | 4.0 | 4.0 | Included | xczu9eg-ffvb1156-2-e |
| bd_639e_0_r_sync_0 | Up-to-date | No changes required | *(3) | Processor System | 5.0 | 5.0 (Rev. 12) | Included | xczu9eg-ffvb1156-2-e |
| | | | | Reset | (Rev. | | | |
| | | | | | 12) | | | |
| bd_639e_0_rx_0 | Up-to-date | No changes required | *(4) | MIPI CSI-2 Rx | 1.0 | 1.0 (Rev. 6) | Purchased | xczu9eg-ffvb1156-2-e |
| | | | | Controller | (Rev. | | | |
| | | | | | 6) | | | |
| bd_639e_0_vfb_0_0 | Up-to-date | No changes required | Change | Video Format | 1.0 | 1.0 (Rev. 8) | Included | xczu9eg-ffvb1156-2-e |
| | | | Log not | Bridge | (Rev. | | | |
| | | | available | | 8) | | | |
| bd_639e_0_phy_0_hssio_rx | Up-to-date | No changes required | *(5) | High Speed | 3.2 | 3.2 (Rev. 2) | Included | xczu9eg-ffvb1156-2-e |
| | | | | SelectIO Wizard | (Rev. | | | |
| | | | | | 2) | | | |
| bd_639e_0_vfb_0_0_axis_converter | Up-to-date | No changes required | *(6) | AXI4-Stream Data | 1.1 | 1.1 (Rev. 13) | Included | xczu9eg-ffvb1156-2-e |
| | | | | Width Converter | (Rev. | | | |
| | | | | | 13) | | | |
| bd_639e_0_vfb_0_0_fifo | Up-to-date | No changes required | *(7) | FIFO Generator | 13.2 | 13.2 | Included | xczu9eg-ffvb1156-2-e |
| mipi_csi2_rx_ctrl_v1_0_6_fc_322048 | Up-to-date | No changes required | *(8) | FIFO Generator | 13.2 | 13.2 | Included | xczu9eg-ffvb1156-2-e |
| mipi_csi2_rx_ctrl_v1_0_6_fifo0 | Up-to-date | No changes required | *(9) | FIFO Generator | 13.2 | 13.2 | Included | xczu9eg-ffvb1156-2-e |
| mipi_csi2_rx_ctrl_v1_0_6_fifo1 | Up-to-date | No changes required | *(10) | FIFO Generator | 13.2 | 13.2 | Included | xczu9eg-ffvb1156-2-e |
| mipi_csi2_rx_ctrl_v1_0_6_fifo2 | Up-to-date | No changes required | *(11) | FIFO Generator | 13.2 | 13.2 | Included | xczu9eg-ffvb1156-2-e |
*(1) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/mipi_csi2_rx_subsystem_v3_0/doc/mipi_csi2_rx_subsystem_v3_0_changelog.txt
*(2) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/mipi_dphy_v4_0/doc/mipi_dphy_v4_0_changelog.txt
*(3) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/proc_sys_reset_v5_0/doc/proc_sys_reset_v5_0_changelog.txt
*(4) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/mipi_csi2_rx_ctrl_v1_0/doc/mipi_csi2_rx_ctrl_v1_0_changelog.txt
*(5) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/high_speed_selectio_wiz_v3_2/doc/high_speed_selectio_wiz_v3_2_changelog.txt
*(6) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/axis_dwidth_converter_v1_1/doc/axis_dwidth_converter_v1_1_changelog.txt
*(7) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/fifo_generator_v13_2/doc/fifo_generator_v13_2_changelog.txt
*(8) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/fifo_generator_v13_2/doc/fifo_generator_v13_2_changelog.txt
*(9) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/fifo_generator_v13_2/doc/fifo_generator_v13_2_changelog.txt
*(10) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/fifo_generator_v13_2/doc/fifo_generator_v13_2_changelog.txt
*(11) c:/Xilinx/Vivado/2017.3/data/ip/xilinx/fifo_generator_v13_2/doc/fifo_generator_v13_2_changelog.txt
Below is the log for update_ip command:
upgrade_ip [get_ips mipi_*]
WARNING: [Coretcl 2-1042] No IP was identified for upgrade.
None
以上来自于谷歌翻译
以下为原文
report_ip_status
IP Status Summary
| | | | | Subsystem | | | | |
| | | | | | 12) | | | |
| | | | | | 6) | | | |
| | | | | | 2) | | | |
| | | | | | 13) | | | |
