是否有详细描述在使用MPLAB X IDE或IPE与ICD3或4时采取什么验证步骤的文档?我们已经看到了IPE的“成功”,但是回读显示了一个空的内存字段,我们也看到了间歇性代码的运行——肯定是校验和还是读回?当我点击“制作和程序设备”时,需要采取什么具体的步骤来验证?谢谢您
以上来自于百度翻译 以下为原文 Is there documentation that describes _in detail_ what verification steps are taken when using MPLAB X IDE OR IPE with a ICD3 or 4? We have seen a 'success' with the IPE yet a read back shows an empty memory field we have seen intermittent code running as well - surely a checksum or a read back takes place? what _specific_ steps are taken for verification when I click 'make and program device'? Thank You |
3个回答
任何由工具实际编程的内存都将被读取和验证。
以上来自于百度翻译 以下为原文 Any memory that was actually programmed by the tool will be read back and verified. |
这就是我们所设想的,但我要求提供直接说明这一点的文档。我们已经成功地编程了许多板,但是它在IPE软件中给出了一个“成功”的1个板,但是在手动读回时仍然是空的,并且在第二个板上它间歇地工作,并且“修复”再次闪烁固件。如果恰当地进行比较,那就毫无意义了。
以上来自于百度翻译 以下为原文 That is what we assumed, but I am asking for documentation that directly states this. We have programmed many boards successfully, but one 1 of the boards it gave a 'success' within the IPE software but was still empty on a manual read back, and on a second board it worked intermittently, and the 'fix' was flashing the firmware again... which makes no sense if it properly does a comparison. |
如果未加载HEX文件,则传递空白。在编程之前验证校验和。
以上来自于百度翻译 以下为原文 If the Hex file was not loaded then Blank is Passed. Verify the Checksum before programming. |
5250 浏览 9 评论
2037 浏览 8 评论
1958 浏览 10 评论
3218 浏览 3 评论
2266 浏览 5 评论
790浏览 1评论
682浏览 1评论
611浏览 1评论
686浏览 0评论
584浏览 0评论
GMT+8, 2024-12-29 11:09 , Processed in 1.509268 second(s), Total 80, Slave 64 queries .
