每个FPGA系列的配置用户指南中都讨论了INIT_B和DONE引脚。
通常,每个FPGA的INIT_B引脚独立上拉至配置组的VCCO。
如果您认为可能存在开机电源稳定性问题,那么您可能需要使用“电源良好”信号来阻止配置。
如果您希望所有设备在配置结束时一起开始运行,那么您将DONE引脚连接在一起,如果无关紧要,那么DONE引脚可以是独立的。
在任何一种情况下,在DONE上使用强上拉(200-400ohm)到配置组的VCCO,或者在最后一个设备上配置DRIVEDONE的比特流选项。
这是为了确保DONE信号的上升时间小于一个CCLK周期。
------您是否尝试在Google中输入问题?
如果没有,你应该在发布之前。太多结果?
尝试添加网站:www.xilinx.com
以上来自于谷歌翻译
以下为原文
INIT_B and DONE pins are discussed in each FPGA family's Configuration User Guide.
In general, INIT_B pins of each FPGA are independently pullup up to the VCCO of the configuration bank. If you think that you may have power-on power supply stability issues then you may want to use a "power good" signal to hold off configuration.
If you want all devices to start operating together at the end of configuration then you connect the DONE pins together, if it doesn't matter then the DONE pins can be independent. In either case, use either a strong pullup (200-400ohm) on DONE to the VCCO of the configuration bank, or the bitstream options of DRIVEDONE on the last device to be configurated. This is to ensure that DONE signal has a rise time of less than one CCLK cycle.
------Have you tried typing your question into Google? If not you should before posting.
Too many results? Try adding site:www.xilinx.com
如果没有,你应该在发布之前。太多结果?
以上来自于谷歌翻译
以下为原文
