如果你有5系列或ASRU N卡,你有额外的功能来控制夹具通信,有USB信号路由与Cover Extend一起使用,所以虽然这些不是'官方'USB - 它可以用于与继电器板通信
还有一个专用的夹具电源,可以从测试计划打开和关闭,虽然这不是直接解决你的VPC查询,然后它是VPC的另一个选项,我的建议是做一个小的bt基本例程并尝试它
在您的笔记本电脑上 - 测试开发软件相对便宜,您可以尝试这些体验,而不会占用您的测试头,谢谢
以上来自于谷歌翻译
以下为原文
If you have series 5, or ASRU N card, you have additional cabilities to control in fixture communications
there is USB signals routed for use with Cover Extend, so whilst these are not 'official' USB - it will work for communicating with a relay board
there is also a dedicated fixture power supply, that can be turned on and off from testplan,
whilst this is not directly addressing your VPC query, then its another option
for VPC, my recommendation would be to make a small bt basic routine and try it on your laptop - test development software is relatively inexpensive and you can try these experiements without tying up your testhead,
thanks
以上来自于谷歌翻译
以下为原文
thanks
