我有三个复选框在我的网页上,我想禁用剩下的两个盒子时,其中之一被检查。有人有什么有用的建议吗?
以上来自于百度翻译 以下为原文 Hi to all. I have three check boxes on my webPage and I would like to disable the remaining two boxes when one of them gets checked. If anyone has any useful suggestion? |
6个回答
通过取消复选框作为取消检查事件的一部分,可以禁用复选框。
以上来自于百度翻译 以下为原文 You can disable a check box by having it recheck itself as part of an uncheck event. |
你的意思是:禁用字段=检查字段?但我需要另外两个来依赖检查。
以上来自于百度翻译 以下为原文 You mean something like .disable field = .checked field? But I need the other two to depend on one that is checked. |
一个复选框可以有两个事件,一个是选中的(未选中-&检查),另一个是未选中的(检查-gt;未选中)。通常,这些事件对应用程序中的其他小部件或变量起作用。但是没有什么可以阻止您设置一个未检查的事件,将复选框的状态设置为选中。因此,如果用户试图取消复选框,它将重置其状态以检查。您可以为两个要保持固定的复选框执行此操作。
以上来自于百度翻译 以下为原文 A checkbox can have two events, one if it is checked (unchecked->checked) and a second if it is unchecked (checked->unchecked). Normally these events do something to some other widget or variable in the application. But there is nothing to prevent you from setting up an unchecked event that sets the state of the checkbox back to checked. So if a user tries to uncheck the checkbox it will reset its state back to check. You can do this for both of the checkboxes you want to stay fixed. |
那也行得通。在一组中的所有单选按钮中,每次只能声明一个。
以上来自于百度翻译 以下为原文 That would work as well. Among all the radio buttons in a group, only one can be asserted at a time. |
我用一个if语句解决了这个问题,现在它工作得很好。
以上来自于百度翻译 以下为原文 I solved the problem with one if statement now it works fine. |
5248 浏览 9 评论
2036 浏览 8 评论
1956 浏览 10 评论
3217 浏览 3 评论
2264 浏览 5 评论
783浏览 1评论
677浏览 1评论
602浏览 1评论
684浏览 0评论
581浏览 0评论
GMT+8, 2024-12-26 22:29 , Processed in 1.456453 second(s), Total 88, Slave 72 queries .
