你好,
从“编程EZ-USB®FX3μC处理器端口作为同步从FIFO”的应用模式来看,如果选择SPI,则不支持32位数据总线宽度。启动后,我使用SPI(GPIO(53)-SPILSCK和GPIO(56)-SPIXMOSI)来配置
FPGA,然后使GPFI到32位从FIFO模式,显然是可行的。在固件运行时,我想再次用SPI接口重新配置FPGA,但在那个时候,GPIF是32位从FIFO模式,我可以停止GPIF或切换到16位模式,使用SPI重新配置FPGA,SW
tiTCH到32位奴隶FIFO吗?
谢谢您!
以上来自于百度翻译
以下为原文
Hi,
From the application mode of "Programming EZ-USB® FX3™ Processor Port as Synchronous Slave FIFO", 32 Bit data bus width is not supported if SPI is selected. After bootup, I use SPI (GPIO[53] - SPI_SCK and GPIO[56] - SPI_MOSI) to configure FPGA, then I enable GPFI to 32-bit slave FIFO mode, it is obviously doable. During firmware runtime, I want to re-configure FPGA with SPI interface again, but at that monent, GPIF is 32-bit slave FIFO mode, Can I stop GPIF or switch to 16-bit mode, using SPI re-configure FPGA, and swtich to 32-bit slave FIFO again?
Thank you!
