嗨,大家好,
我已经使用32位从属FIFO和我想用GPIO [ 53:56 ]作为一个GPIO作为SPI线读写SPI Flash外部连接板。而且我需要使用UART来打印调试消息。在FX3,使用32位GPIF的时候,然后spi_mosi和uart_tx映射到同一个GPIO [ 55 ]。可以一次同时使用UART和GPIO GPIO [ 55 ]吗?我尝试通过重新配置IO矩阵,但它不起作用。有没有可能做到这一点? 提前感谢。 以上来自于百度翻译 以下为原文 hi all, I have use 32 bit slave fifo and I want to use GPIO[53:56] as an GPIO used as spi lines for read/write to SPI flash externally connected to a board. And also I need to use Uart for printing debug messages. In FX3, when using 32 bit gpif, then SPI_MOSI and UART_TX are mapped to the same GPIO[55]. Is it possible to use both UART and GPIO in GPIO[55] at a time ?. I tried by reconfiguring the IO matrix, but it wont work. Is there any possible way to do this? Thanks in advance. |
你好,
如果将GPIF数据总线宽度配置为32位宽,那么只能使用UART而不使用SPI。要在32位GPIF模式中使用UART,需要设置IOYCFG.ISDQ32位= CyTrime:IOYCFG.LPPMODE = CyuU3pIIO-MatRIX-LPPIDEAL;以及IOYCFCGUESART=CyTress; 要使用UART和SPI,您需要配置GPIF总线宽度为16位宽。 IOFCFG.ISDQ32位=CyFalm;IOICFG.LPPMODE=CyuU3pIIO-MyRixLPPH默认值;IOIF CFU.UUART=CyTrand;IOYCFG.UESSPI=Cytru. 当做, 血竭 以上来自于百度翻译 以下为原文 Hi, If you configure GPIF data bus width to be 32 bit wide, then you can use only UART and not SPI. To use UART in 32 bit GPIF mode you need to set io_cfg.isDQ32Bit = CyTrue; io_cfg.lppMode = CY_U3P_IO_MATRIX_LPP_DEFAULT; and io_cfg.useUart = CyTrue; To use both UART and SPI you need to configure GPIF bus width to be 16 bit wide and io_cfg.isDQ32Bit = CyFalse; io_cfg.lppMode = CY_U3P_IO_MATRIX_LPP_DEFAULT; io_cfg.useUart = CyTrue; and io_cfg.useSpi = CyTrue; Regards, Hemanth |
如HEMANTH所建议的,当IO矩阵被配置为32位时,您不能使用SPI端口(但您仍然可以从SPI接口启动FX3)。
您需要从上面的两个选项中选择一个配置。 以上来自于百度翻译 以下为原文 As suggested by Hemanth, you could not use SPI port when the IO matrix is configured as 32-bit(but you can still start FX3 from SPI interface). You need to choose one configuration from the twos above. |
756个成员聚集在这个小组
加入小组2122 浏览 1 评论
1864 浏览 1 评论
3680 浏览 1 评论
1800 浏览 6 评论
1543 浏览 1 评论
595浏览 2评论
444浏览 2评论
447浏览 2评论
400浏览 2评论
1074浏览 2评论
GMT+8, 2025-1-6 07:20 , Processed in 0.961291 second(s), Total 80, Slave 64 queries .
