请高手帮我看看,我想用STM32F207的DMA+DAC+tiM6输出正玄波,现在遇到问题,不知道哪里不对,总是没有预期结果出来。有知道的请加我微信***,谢谢。代码如下:
#define DAC1_DMA_ADDR 0x40007408 //这个是DMA初始化要用的外设地址。是DAC_DHR12R1的地址 以下数组为余弦函数的数据 ,标题写的正玄波,不严谨,这里关系不大。 uc32 DAC_cosTAB[] = { 4000 ,3998 ,3990 ,3978 ,3962 ,3940 ,3914 ,3883 , 3848 ,3808 ,3764 ,3715 ,3663 ,3606 ,3546 ,3482 , 3414 ,3343 ,3269 ,3191 ,3111 ,3028 ,2943 ,2855 , 2765 ,2674 ,2581 ,2486 ,2390 ,2293 ,2196 ,2098 , 2000 ,1902 ,1804 ,1707 ,1610 ,1514 ,1419 ,1326 , 1235 ,1145 ,1057 ,972 ,889 , 809 ,731 ,657 , 586 ,518 ,454 ,394 ,337 ,285 , 236 ,192 , 152 ,117 , 86 , 60 , 38 , 22 , 10 , 2 , 0 , 2 , 10 , 22 , 38 , 60 , 86 ,117 , 152 ,192 ,236 ,285 ,337 ,394 ,454 ,518 , 586 ,657 ,731 ,809 ,889 ,972 ,1057 ,1145 , 1235 ,1326 ,1419 ,1514 ,1610 ,1707 ,1804 ,1902 , 2000 ,2098 ,2196 ,2293 ,2390 ,2486 ,2581 ,2674 , 2765 ,2855 ,2943 ,3028 ,3111 ,3191 ,3269 ,3343 , 3414 ,3482 ,3546 ,3606 ,3663 ,3715 ,3764 ,3808 , 3848 ,3883 ,3914 ,3940 ,3962 ,3978 ,3990 ,3998 , 4000 }; 说明:管脚时钟,TIM时钟,DMA时钟都已经开了。 引脚配置代码段如下: GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_OType = GPIO_OType_OD; GPIO_Init(GPIOA, &GPIO_InitStructure); DMA的配置如下: void DAC_DMA_Config(void) { DMA_InitTypeDef DMA_InitStructure; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE); DMA_DeInit(DMA1_Stream5); //DMA_StructInit( &DMA_InitStructure); DMA_InitStructure.DMA_Channel = DMA_Channel_7; DMA_InitStructure.DMA_PeripheralBaseAddr = DAC1_DMA_ADDR; DMA_InitStructure.DMA_Memory0BaseAddr = (u32)DAC_cosTAB; DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral; DMA_InitStructure.DMA_BufferSize = 128; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;//DMA_PeripheralDataSize_Byte; DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_HalfWord;// DMA_MemoryDataSize_Byte; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA_Mode_Normal; DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; DMA_InitStructure.DMA_FIFOMode=DMA_FIFOMode_Disable; DMA_InitStructure.DMA_FIFOThreshold=DMA_FIFOThreshold_1QuarterFull; DMA_InitStructure.DMA_MemoryBurst=DMA_MemoryBurst_Single; DMA_InitStructure.DMA_PeripheralBurst=DMA_PeripheralBurst_Single; DMA_Init(DMA1_Stream5, &DMA_InitStructure); DMA_Cmd(DMA1_Stream5, ENABLE); //DMA_ITConfig(DMA1_Stream5, DMA_IT_TC|DMA_IT_TE,ENABLE); } DAC的配置如下: void DAC_Configuration(void) { DAC_InitTypeDef DAC_InitStructure; DAC_DeInit(); DAC_StructInit(&DAC_InitStructure); DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;//²»²úÉú²¨ÐÎ DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Disable; //²»Ê¹ÄÜÊä³ö»º´æ DAC_InitStructure.DAC_Trigger = DAC_Trigger_T6_TRGO;//DAC´¥·¢Æ÷Ϊ¶¨Ê±Æ÷6´¥·¢ DAC_Init(DAC_Channel_1, &DAC_InitStructure); // DAC_Cmd(DAC_Channel_1, ENABLE); // DAC_DMACmd(DAC_Channel_1, ENABLE); // } TIM6的配置如下: /////////////////////////// TIM6用作DAC的触发 配置如下 ////////////////////////////////////////////////////////////////////////////// TIM_TimeBaseStructInit(&TIM_TimeBaseStructure); TIM_TimeBaseStructure.TIM_Period = 50; // TIM_TimeBaseStructure.TIM_Prescaler = 0x0; TIM_TimeBaseStructure.TIM_ClockDivision = 0x0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure); TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update); TIM_Cmd(TIM6, ENABLE); ///////////////////////////////////////////////////////////////////////////////////////////////////////// 请高手帮我看看,我想用STM32F207的DMA+DAC+TIM6输出正玄波,现在遇到问题,不知道哪里不对,总是没有预期结果出来。有知道的请加我微信***,谢谢。 |
16个回答
现在出来的波形是什么
楼主使能了DMA中断,但未见到DMA中断处理函数,程序会跑飞的。
我是用的keil建工程的,数组数据没有问题的,我在单独DAC的情况下,可以看到标准的余弦波。这个数组决定的波形的幅值,跟频率没有关系,都是这些数据,我在单DAC的情况下,能输出5K以下的任意频率余弦波型。后面的DMA的问题,我再仔细看看,DMA我不太会用。谢谢,谢谢 ,谢谢
现在出来的波形是不对的,幅值和波形都不对,就是波浪线,像是三角波 和正玄波的还有很多很多的毛刺。还不受控,就是改变数据,波形也是那个样子。 |
中断函数有的,忘记贴上来了,只是中断函数里没有任何处理。程序应该没有跑飞的。函数如下: void DMA1_Stream5_IRQHandler(void) { if( DMA1->HISR & ( DMA_FLAG_TCIF7|DMA_FLAG_HTIF7|DMA_FLAG_TEIF7|DMA_FLAG_DMEIF7|DMA_FLAG_FEIF7 ) ) { DMA1->HIFCR = (uint32_t)((DMA_FLAG_TCIF7|DMA_FLAG_HTIF7|DMA_FLAG_TEIF7|DMA_FLAG_DMEIF7|DMA_FLAG_FEIF7) & 0x0F7D0F7D ); } } |
DMA我用的是循环模式,还需要重置数组指针吗?
有大神来帮帮我吗?
DMA循环只是说DMA循环,不没有指定DMA的数据地址。数据DMA到DAC完了后,需要重置数据指针 |
具体该怎么做呢?我用了你的代码,出来了杂波,不是正玄波,估计是没有重置数组指针,请问这个在什么时候什么地方做这一步动作?谢谢 |
在哪里操作呢?DMA中断里?
你是用什么编译的,用什么建工程的,我的keil里好像没有文件:stm32f7xx_hal.h ,所以也没办法#include "stm32f7xx_hal.h"的,
我用的是STM32F207。
问题解决了,其实我的那个程序是可以的,就是一个小地方没有搞对,谢谢你的帮助。我知道问题在哪里了 。谢谢!!!谢谢谢!!!!!!!
请问你是在哪里工作?是否可以加微信好友,或者QQ好友?
请问你是在哪···‘·‘·‘’’’里工作,是否可以加 微##¥信@!#好···友,或者Q·@为好···友??
STM32串口接受中断使用C++STL中的queue导致所有中断失效
1795 浏览 1 评论
2555 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1271 浏览 0 评论
3419 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
3207 浏览 4 评论
GMT+8, 2025-1-28 13:44 , Processed in 0.948982 second(s), Total 101, Slave 85 queries .
