扫一扫,分享给好友
大家好,我用的是开发板D3315和V1Y11。我添加了一个PrimeStar来显示我的电池的百分比。当百分比低于20%时,我想把颜色变为红色,所以我这样做:GFxGoLoopObjultHealth*POBJCT3;POBJCTX3= GFXGOLL ObjestDebug(GFXI索引X0,PrimsSARB1);(Akkuladung(AN2C)& lt;=20)// Akkuladung是在100和0之间{GfxGoGlObjObjultMyStand;MEMCPY(&;MyStand,和;GFxSythEngEnEnEy5,SIZEOF(GFXG-GOLOL ObjyPosits));//方案5是绿色的背景色E-PrimeStrusBar gfxGoLoopObjistStudiSeCCESET((gfxgOrgPrimeSrsBar *)POBJCT3),以及(Akkuladung(AN2C)& Gt;20)/(Akkuladung)在100和0之间{GFXGOLYOBORIGHORY MyStudie2;MyStudie2,和gfxyStudioNaMeNeE4,SiZeof(GFXGGOLL ObjyPosits);和/或方案4是PrimeStruBar GFXGoLoGoObjistTysSeriSeCe的绿色背景色((GFXGOL PrimeSrsBar*)POBJECT3),以及GFXO-GOLYObjStutsESET((FXXGOL GORPROSSRISBAR *)POBJCT3),GFX-GOLYPROSSRESBARLD DRAB BARYSTA STA这不管用,如果你能帮我的忙。
以上来自于百度翻译 以下为原文 Hi all, i'm using the development board DM320015 with HARMony V1_11. i added a Progres***ar to show the percent of my battery. I want to change the color to red when the percent goes under 20% so i made this: GFX_GOL_OBJ_HEADER *pObject3; pObject3 = GFX_GOL_ObjectFind(GFX_INDEX_0, ProgressBar1); GFX_GOL_ProgressBarPositionSet(((GFX_GOL_PROGRESSBAR*)pObject3), Akkuladung(an2c)); if (Akkuladung(an2c) <= 20) // Akkuladung is between 100 and 0 { GFX_GOL_OBJ_SCHEME myscheme ; memcpy(&myscheme,&GFX_SCHEME_NAME_5, sizeof(GFX_GOL_OBJ_SCHEME)); // Scheme 5 is with the green background color for the progres***ar GFX_GOL_ObjectStyleSchemeSet(((GFX_GOL_PROGRESSBAR*)pObject3), &myscheme); GFX_GOL_ObjectStateSet(((GFX_GOL_PROGRESSBAR*)pObject3), GFX_GOL_PROGRESSBAR_DRAW_BAR_STATE); } if (Akkuladung(an2c) > 20) // Akkuladung is between 100 and 0 { GFX_GOL_OBJ_SCHEME myscheme2 ; memcpy(&myscheme2,&GFX_SCHEME_NAME_4, sizeof(GFX_GOL_OBJ_SCHEME)); // Scheme 4 is with the green background color for the progres***ar GFX_GOL_ObjectStyleSchemeSet(((GFX_GOL_PROGRESSBAR*)pObject3), &myscheme2); GFX_GOL_ObjectStateSet(((GFX_GOL_PROGRESSBAR*)pObject3), GFX_GOL_PROGRESSBAR_DRAW_BAR_STATE); } this doesn't work so if you can help me Thanks Attached Image(s) |
如果方案是在RAM中,那么您可以编辑方案和重绘。或者您可以指向并设置它,而不需要复制。否则它看起来是正确的。
以上来自于百度翻译 以下为原文 If you scheme is in RAM then you can just edit the scheme and redraw. Or you can point to the and set it without the copying. Otherwise it appears to be correct. |
我尝试了一切,但它不起作用。我用另一个方案创建了另一个PrimeStBar(禁用和不可见),我现在正在使用它,它/ Ak/ulkAdUng.()返回INTGFxGOLYObjObjultHeule*PoBubj.PoBoCux= GFxGoLo.ObjestDebug(GFXI索引x0,PrimeStBAR1);* POBJeTeNeXPo.PbjjTeNeX= GFXGOLL ObjeDebug(GFXI索引x0,PrimsSbBAR2);GFxGoLePraseSrBoStPosivSt集((GfxGoLePrimeStrubBar)PoBube),Akkuladung(AN2C);GFxGoLoopReSrsBARSITIONSETSET(((FxxGoLePrReSrsBar*)POBJeTeNeX),Akkuladung(AN2C));IF(Akkuladung(AN2C)& lt;=40){GFXGOLGOLL ObjistStistes RFxGoGlObjultHeope*(PbBoT)、GFxGOL PrimeSrSbAuHiDeStIt';GFxGoLoObjistStuteSeT((gfxgOlgObjyHealthHead *)POBJeTeNeXT)、GFxGoLoopReSsSbAdRuxStand状态;}(Akkuladung(AN2C)& Gt;40){GFXGOLGOOL ObjutStestESET((gfxgGOLL ObjyHealthHead *)POBCEDE)、GFXGOL GORPROSSRESBARUDRAYSTATE);t((g)解决方案,对大家有帮助。谢谢。
以上来自于百度翻译 以下为原文 I tried everything but it doesn't work. I created another Progres***ar (DISABLED and NOT VISIBLE) with another scheme (Color1=BRIGHTRED) I'm using it now and it works: // Akkuladung() returns an int GFX_GOL_OBJ_HEADER *pObject; pObject = GFX_GOL_ObjectFind(GFX_INDEX_0, ProgressBar1); GFX_GOL_OBJ_HEADER *pObjectNEW; pObjectNEW = GFX_GOL_ObjectFind(GFX_INDEX_0, ProgressBar2); GFX_GOL_ProgressBarPositionSet(((GFX_GOL_PROGRESSBAR*)pObject), Akkuladung(an2c)); GFX_GOL_ProgressBarPositionSet(((GFX_GOL_PROGRESSBAR*)pObjectNEW), Akkuladung(an2c)); if (Akkuladung(an2c) <= 40) { GFX_GOL_ObjectStateSet(((GFX_GOL_OBJ_HEADER*)pObject), GFX_GOL_PROGRESSBAR_HIDE_STATE); GFX_GOL_ObjectStateSet(((GFX_GOL_OBJ_HEADER*)pObjectNEW),GFX_GOL_PROGRESSBAR_DRAW_STATE); } if (Akkuladung(an2c) > 40) { GFX_GOL_ObjectStateSet(((GFX_GOL_OBJ_HEADER*)pObject),GFX_GOL_PROGRESSBAR_DRAW_STATE); } If there is another solution with the scheme, it will be helpful. Thanks |
5275 浏览 9 评论
2048 浏览 8 评论
1962 浏览 10 评论
3225 浏览 3 评论
2272 浏览 5 评论
809浏览 1评论
704浏览 1评论
638浏览 1评论
698浏览 0评论
594浏览 0评论
GMT+8, 2025-1-6 16:24 , Processed in 1.121626 second(s), Total 80, Slave 64 queries .
