有一个Env文件来设置环境变量。
运行命令如下: #. Env (. + 空格 + Env) 运行了这个命令以后就可以正常用Make编译工程了。 Env的文件内容如下。现在就是想知道#BASE 到#ENV之间这段代码的意思。 #BASE if [ -z "$ZSH_NAME" ] && [ "x$0" = "x./environment" ]; then echo "Error: This script needs to be sourced. Please run as ". ./Env"" exit 1 else if [ -n "$BASH_SOURCE" ]; then SDK_PATH="`dirname $BASH_SOURCE`" else SDK_PATH="`pwd`" fi SDK_PATH=`readlink -f "$SDK_PATH"` export SDK_PATH fi #Env export PS1="[e[32;1m][am335x][e[0m]:w> " export PATH=$PATH:${SDK_PATH}/tools/x86-linux-gnu/bin export OE_QT_INSTALL_PATH=${SDK_PATH}/tools/ARM-linux-gnueabihf/usr/qt-4.8.6 export QMAKESPEC=${OE_QT_INSTALL_PATH}/mkspecs/qws/linux-arm-linux-gnueabihf-g++ export OE_QT_INSTALL_HEADERS=${OE_QT_INSTALL_PATH}/include export OE_QT_INSTALL_LIBS=${OE_QT_INSTALL_PATH}/lib export OE_QT_INSTALL_BIN_MOC=${OE_QT_INSTALL_PATH}/bin/moc export OE_QT_INSTALL_BIN_UIC=${OE_QT_INSTALL_PATH}/bin/uic |
197个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2207 浏览 6 评论
2008 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4566 浏览 1 评论
GMT+8, 2025-1-13 22:15 , Processed in 0.508447 second(s), Total 76, Slave 57 queries .
