是德科技
李佳
7年用户 194经验值
83620A组件级别信息是否仍然可用?
83620的组件级别信息是否仍然可用?
我知道在某些时候它是,我正在寻找关于A20射频接口板J4上的引脚输出的信息,特别是引脚4,5,13,​​15所有其他引脚似乎是GND和电源但这些似乎是一些
一种控制线,我正在阅读旧的惠普期刊中的LB模块的描述,但它并没有表明有任何控制线来自或进入LB模块,但我的假设是那些可能是锁定检测线和
其他一些自测试线,我会感激任何帮助!我从打捞中得到一个旧的83620B试图修复,它似乎工作正常,除了LB模块并发送它不是一个选项,因为它太昂贵了!
以上来自于谷歌翻译
     以下为原文
  Is component level info for the 83620 still available ? i know at some point it was , i am looking for information on the pin-out on J4 of A20 RF Interface board especially pin 4 , 5, 13, 15 all the other pins seem to be GND and power but those seem to be some kind of control lines, i was reading the description of the LB module in a old HP journal but it does not indicate that there are any control lines coming from or going to the LB module but my assumption is that those are probably lock detect lines and some other self-test lines, i would appreciate any help !
I got a old 83620B from salvage im trying to repair , it seems to work fine except of the LB module and sending it in is not a option since its too costly !
回帖(3)
沈雨露
2019-3-22 11:03:20
8510 Fan,我不是83620A专家,但在安捷伦内部网上搜索过,没有找到任何组件级信息包(CLIP)。
它们有时可以在内部列出并可供下载。我无法找到任何东西。
如果Santa Rosa的任何人有更多信息,请发帖。迈克
以上来自于谷歌翻译
     以下为原文
  8510 Fan,
I'm not a 83620A expert, but searched the Agilent intranet and didn't find any Component Level Information Packets (CLIP).  They can sometimes be listed internally and available to download.
Sorry I couldn't find anything.  If anyone in Santa Rosa has more information please post.
Mike
李欢
2019-3-22 11:22:16
嗨-I看起来也是。
找不到任何东西.-抱歉。
以上来自于谷歌翻译
     以下为原文
  Hi -
I looked too.  Couldn't find anything.
- Sorry.
庞兴玉
2019-3-22 11:29:31
我注意到我的笔记,大多数RF接口对于下面列出的低频段模块I引脚是相同的。
请问Low Band模块的故障是什么?
我很了解它们并修复低频段模块。
我不认为引脚不会有帮助。
您可以给我发电子邮件以获得进一步的帮助.service @ teplus.com
针脚4:DetBW_DRV
pin5:DET_TC_OFS
引脚13:DET_TC_LSO
pin:15:VTUNE
希望这可以帮助,
乔L.
以上来自于谷歌翻译
     以下为原文
  I looked at my notes and most of the RF interfaces are the same for low band module I listed pins below.  May I ask what is failure of the Low band module?  I know them well and repair the low band module. I do not think the pin out is not going to help.  You can email me for further assistance. service@teplus.com
pin 4 : DetBW_DRV
pin5 :  DET_TC_OFS
pin 13: DET_TC_LSO
pin: 15: VTUNE
Hope this helps,
Joe L
