您好,我在MSP430F5659(ti)有一个发展,我想添加一个WiFi模块(Atmel AtWiC1500),我在william hill官网
上读到,我必须写自己的低级别驱动程序来使用它。3)使用Atmel AtWiC1500。这有一个内置的堆栈,所以我们可以节省一些代码空间,并有一个非常丰富的功能集。我们需要编写自己的低级驱动程序,所有的文档都是基于Atmel CPU的。但是,驱动程序的源是可用的,并且接口写得很好。有人使用这个模块并编写了低级驱动程序吗?Atmel提供的信息不足以与另一个微控制器一起使用。所有的帮助都是受欢迎的。Juan Manuel,
以上来自于百度翻译 以下为原文 Hello, I have a development in MSP430F5659 (TI) and I want to add a wifi module (ATMEL ATWINC1500), I read in the forum that I have to write my own low level driver to use it. 3) Use the Atmel ATWINC1500. This has a built in stack, so we can save some code space, and has a very rich feature set. We would need to write our own low level driver, and all the documentation is based around Atmel CPUs. However, source for the driver is available and the interface is well written. Has anyone worked with this module and written a low-level driver? The information provided by ATMEL is not sufficient for use with another microcontroller. All help is welcome. Regards, Juan Manuel |
3个回答
这个模块是由AdfRuIT在他们的ARDUINO 0版本(称为羽毛M0 WiFi)使用的。这里提供的驱动程序源代码是:HTTPS://GITHUBCOM/ADAFRUIT/ADAFRUITIWIN WC1500。您可以使用此作为开发MSP的自定义驱动程序的基础。
以上来自于百度翻译 以下为原文 This module is used by Adafruit on their version of the Arduino Zero (called the Feather M0 WiFi). Driver source code is available here: https://github.com/adafruit/Adafruit_WINC1500. You could use this as a basis for developing a custom driver for the MSP. |
非常感谢你的回复。这很有帮助。我会分析一下,看看我能用什么。问候,Juan Manuel。
以上来自于百度翻译 以下为原文 Thank you very much for the reply. This is very helpful. I'll analyze it to see what I can use. Regards, Juan Manuel |
不客气。当然,你可以通过羽毛M0 WiFi板,让它在任何时候运行,除非你对MSP430有特定的需求。
以上来自于百度翻译 以下为原文 You are welcome. Of course, you could just by the Feather M0 WiFi board and have it up and running in no time, unless you have a specific need for the MSP430. |
5248 浏览 9 评论
2037 浏览 8 评论
1957 浏览 10 评论
3218 浏览 3 评论
2265 浏览 5 评论
788浏览 1评论
679浏览 1评论
608浏览 1评论
685浏览 0评论
582浏览 0评论
GMT+8, 2024-12-28 08:54 , Processed in 1.247029 second(s), Total 80, Slave 64 queries .
