你好,谢谢你的回复。我用PICTIT3作为独立的程序员,PICTIT3版本是BUR15247148,意思是,我把代码上传到应用程序并把它烧到集成威廉希尔官方网站
上。这种编程方式会烧毁16F1933和其他PIC。因为PICIT3版本没有更新,所以我没有找到12F1572的问题,我试图在网络中找到几天,但是找不到,所以我需要一个更新的3版本,可以检测到1572。至于MPLAB,我使用CCS C com。PILER和只使用PICIT3在PIC MCU上导入HEX文件。请建议我在哪里可以找到一个解决方案,如果这不是正确的william hill官网
/地方?因为我不太熟悉这个william hill官网
以上来自于百度翻译
以下为原文
Hi,
Thank you for your reply.
I use the pickit3 as a STAND ALONE PROGRAMMER, the pickit3 version is BUR152974148, meaning, I upload the code to the application and burn it to the ic. this way of programming burn 16f1933 and other pic's. the problem it doesn't detect the 12f1572 because the picit3 version is not updated and I tried to find in the web for a few days and couldn't find so I need an updated version of the pickit 3 that can detect the 1572.
As to MPLAB - I use CCS C Compiler And Use only the PICIT3 to import hex file on the pic mcu's.
Please advice where can I find a solution if this not the right Forum/place? as I am not oftenly familiar with this forum.
Regards
以上来自于百度翻译
以下为原文
Hi,
Regards
