嗨,我正在使用MPLAB X IDE V3.40选择器IT3i解决两件事:A)“运行程序”B)“调试模式”我如何才能把程序发送到PIC12F1572,以便把我的程序存储在PIC中,而不在我关机和PIC上电源时被删除?非常感谢。
以上来自于百度翻译
以下为原文
Hi,
I am using MPLAB X IDE v3.40
PICK it3
I tryed two things:
a) "Run the program"
b) "Debug mode"
How can I send the program to PIC12F1572 in order to put my program and be storage in PIC without be deleted when I power off and power on the PIC?
Thank you a lot
Connecting to MPLAB PICkit 3...
Currently loaded firmware on PICkit 3
Firmware Suite Version.....01.44.26
Firmware type..............Enhanced Midrange
Programmer to target power is enabled - VDD = 3.250000 volts.
Target device PIC12F1572 found.
Device ID Revision = 2000
Device Erased...
Programming...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x1bf
configuration memory
Programming/Verify complete
以上来自于百度翻译
以下为原文
Hi,
PICK it3
I tryed two things:
b) "Debug mode"
Thank you a lot
Device Erased...
Programming...
