电子发烧友william hill官网
嗨,
我发现了关于哔声示例的以下注释,你检查了吗? - 确认JP14处于向上位置(以启用STM8 / 128-EVAL上的扬声器) - 通过调节STM8 / 128-EVAL上的RV2电位计位置来验证扬声器音量 问候, lowpowermcu 以上来自于谷歌翻译 以下为原文 Hi, I have found the following notes regarding the beep example, did you checked it ? - Verify that the JP14 is on the up position (to enable the speaker on the STM8/128-EVAL) - Verify the speaker volume by adjusting the RV2 potentiometer position on the STM8/128-EVAL Regards, lowpowermcu |
嗨,
我一直在乱搞这个......我认为问题在于中断没有开始。我改为查询GPIO而不是中断驱动的示例项目,并且它工作正常。 感谢您的输入! 以上来自于谷歌翻译 以下为原文 Hi, I've been messing around with this a bit more...I think the problem was that the interrupt was not firing. I changed to the sample project where the GPIO is polled instead of interrupt driven, and it worked. Thanks for your input! |
2747 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3655 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
359浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
449浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
277浏览 2评论
GMT+8, 2024-12-29 03:09 , Processed in 1.162679 second(s), Total 47, Slave 41 queries .
