是德科技
简白伊
7年用户 207经验值
从Vee 8.51 Pro升级到9.3 Pro有什么建议吗?
几年前,我在Vee 8.51(Windows XP)中开发了一些程序,使用Vee,matlab(包括Vee,不是单独的),.NET 3.5,Access数据库,MS Office 2003和2007.从Agilent 34980A访问数据。
我已经离开了Vee升级的循环一段时间,他们现在想要更新到Vee 9.3 Pro以在更新的Windows 7 PC上运行。
除了学习在Vee中进行的任何UI调整之外,我应该注意哪些问题,已经过时或升级的功能,或者我应该考虑的新功能?
简而言之,代码是按原样运行还是可能需要修改?
谢谢,格雷格
以上来自于谷歌翻译
     以下为原文
  I had developed some programs in Vee 8.51 (Windows XP) a few years back that used Vee, Matlab (Vee included, not separate), .NET 3.5, Access Database, MS Office 2003 then 2007.  Accessing data from an Agilent 34980A.
I have been out of the loop for Vee upgrades for a while and they are now wanting to update to Vee 9.3 Pro to run on a newer Windows 7 PC.
Other than learning whatever UI tweaks have been made in Vee, what issues should I look out for, features that were obsoleted or upgraded, or new features that I should consider?
In short, Will the code run as is or will it likely need modifications?
Thanks,
Greg
回帖(1)
李麒
2019-4-15 09:40:42
从VRF(另一个讨论组通过电子邮件)到目前为止,没有运行旧程序的大问题。
我还没有听说过需要修改任何程序。
但是,您可能需要注意以下内容。
1. Matlab。
第一次在VEE中使用Matlab时需要完成一些步骤。
这是在附带的9.31自述文件中捕获的。
2.仪器驱动程序。
如果您使用Direct IO与34980A通信,它应该可以正常工作。
但是,如果您正在使用任何其他驱动程序,请验证是否可以在Windows 7上安装这些驱动程序。某些IVI驱动程序在安装期间将失败,您可能需要获得支持Windows 7的版本。希望这有助于:) -mk
以上来自于谷歌翻译
     以下为原文
  From VRF (another discussion group via email), no big issue of running older program so far. I have not heard of any program modification is needed. However, you may want to take note of below.
1. Matlab. Some steps need to be done when using Matlab in VEE for the first time. This is captured in 9.31 read me file attached.
2. Instrument driver. If you are using Direct IO to talk to 34980A, it should works fine. However, if you are using any other driver, verify those driver can be installed on Windows 7. Some IVI drivers will failed during installation and you may need to get the version that supports Windows 7.
Hope this helps :)
-mk
附件
