还要注意的是,涉及加密的示例应用程序意味着使用嵌入加密模块,该加密模块仅在EF芯片上可用,其中M的部件号为M。你可以在没有加密模块的情况下得到DEV板。所有用于EC或EFH芯片的应用将在EFM上运行。专门针对EFM的项目仍然可以在EC上工作,但不会有硬件加密的好处。这是相当多以太网的东西,比如WOLFSSL演示。正如上面所说的,EF芯片的ADC示例在EC芯片上根本不起作用,实际上它们完全取代了EF芯片中的不同硅的ADC,因为EC芯片中的一个是非常可怕的。ER项目的选择芯片的事项。John Vickers
以上来自于百度翻译
以下为原文
Also note that the sample applications that involve encryption are meant to use the embedded encryption module that is only available on the EF chips with the M in the part number. You can get the dev board with and without the encryption module. All the application meant for EC or EFH chips will run on the EFM. Projects specifically for the EFM can still work on the EC, but will not have the benifit of the hardware encryption. This is pretty much Ethernet stuff, like the WolfSSL demo.
Also as said above, the ADC examples for the EF chip will not work at all on the EC chip, they actually completely replaced the ADC with different silicon in the EF chip because the one in the EC chip was so horrible.
I can't think of any other projects where the selected chip matters.
John Vickers
以上来自于百度翻译
以下为原文
John Vickers
