扫一扫,分享给好友
我使用MPLAB X IDE V3.35和Hyror 2.0B。我已经使用配置器映射了我的外设和GPIO。现在我想将引脚设置导出到电子表格,以便将它们传递给进行威廉希尔官方网站
板布局的人。在配置器窗口内,按下导出按钮2。显示“导出”菜单。选择“MPLAB和谐配置器引脚图和引脚表”。3。导出按钮在窗口的底部启用。按下“导出”按钮。4。为Excel文件选择一个位置并按下“打开”按钮。在MPLLAB HARMony Configurator窗口中,可以看到数百行,例如:
以上来自于百度翻译 以下为原文 I am using MPLAB X IDE v3.35 and Harmony 2.00b. I have mapped my peripherals and GPIO using the configurator. Now I would like to export the pin settings to a spreadsheet to pass them along to the person doing the board layout. To export the pin settings, I am using the following steps: 1. Inside the Configurator window, press the Export button 2. The Export Menu is displayed. Select "MPLAB Harmony Configurator Pin Diagram and Pin Table". 3. The Export button is enabled at the bottom of the window. Press the "Export" Button. 4. Select a location for the Excel file and press the Open button. In the MPLAB Harmony Configurator window I can see hundreds of lines such as: There are no errors in this tab but there is one silent error. The silent error is an Unexpected Exception in Java (which I have attached). The results are: A PNG file is created but the pin names at the top and bottom of the chip are cropped off of the diagram. The Excel file is not created. A zero byte file with the correct name exists. I was not able to find this as being a known issue. Does this functionality exist in MPLAB v3.30 and Harmony 1.08? I may have created my project using MPLAB v3.30 and Harmony 1.08 and then upgraded to MPLAB v3.35 and Harmony 2.00b. Could the upgrade be causing a problem? Is this tool still too new to use on a large project? Attachment(s) Error during export to Excel.txt (13.58 KB) - downloaded 282 times |
我同意在某些项目上会发生这种情况。几个月前我买了一张票。支持报道,他们已经能够复制的问题,所以它会得到固定在一段时间!也许会再给你一个支持?
以上来自于百度翻译 以下为原文 I agree that is what happens on some projects. I raised a ticket a few months ago. Support reported that they have been able to reproduce the issue, so it will get fixed at some time! Maybe raise another support ticktet? |
5248 浏览 9 评论
2036 浏览 8 评论
1956 浏览 10 评论
3218 浏览 3 评论
2264 浏览 5 评论
788浏览 1评论
678浏览 1评论
608浏览 1评论
685浏览 0评论
582浏览 0评论
GMT+8, 2024-12-27 22:52 , Processed in 1.419798 second(s), Total 76, Slave 60 queries .
