电子发烧友william hill官网
你好,我用的是MRF24J40,它是一个带有1个PAN协调器和1到8个连接设备的星形盘。PAN协调器运行Linux,并用C++编写。该设备在C中实现智能化,PAN协调器与设备之间的通信工作良好。当2个设备同时向PAN协调器发送帧时,仍然存在一个问题。PAN协调器在那时接收OR 1帧。有没有办法处理INTGPIO来处理多个RX?谢谢)
以上来自于百度翻译 以下为原文 Hi, I'm using the MRF24J40 for a star PAN with 1 PAN Coordinator and 1 to 8 connected devices. The PAN Coordinator runs Linux and is written in C++. The devices are witten in C. The communication between the PAN Coordinator and the devices works fine. There is still an issue when 2 devices send a frame to the PAN Coordinator at the same time. The PAN Coordinator receives ony 1 frame at the time. Is there a way to handle the INT GPIO to handle multiple RX ? Thanks :) |
RX中断一次处理一帧。我不知道有什么办法让它等待多个帧。MRF24J40中的接收FIFO仅足够深,一次处理一个最大大小的帧。发送PAN协调器的帧请求确认帧吗?如果是这样,他们都报告传输成功吗?还是报告传输失败?
以上来自于百度翻译 以下为原文 The Rx interrupt handles one frame at a time. I don't know of any way to have it wait for multiple frames. The receive FIFO in the MRF24J40 is only deep enough to handle one maximum sized frame at a time. Do the devices sending frames to the PAN coordinator request an acknowledgement frame? If so, do they both report that transmission was successful? Or does one report an transmission failure? |
您好,是的,设备请求确认(协调员也)。我必须用嗅探器进行测试,以确认它们都报告了一个成功的传输,但我记得是这样的。我启用ACK请求,并清除RXMCR寄存器中的AcKEN位。TXNCON寄存器也被配置为帧重传。我确实有其他问题(尤其是关于如何检测传输失败),但我可能会启动一个新线程。
以上来自于百度翻译 以下为原文 Hello, Yes, the devices request an acknowledgement (the Coordinator too). I have to test with my sniffer to confirm that they both report a successful transmission but I remember that it was the case. I enable ACK request and I clear the ACKEN bit in the RXMCR register. The TXNCON register is also configured for frame retransmission. I do have other questions about that (especially about how to detect a transmission failure) but I'll probably start a new thread. |
5250 浏览 9 评论
2037 浏览 8 评论
1958 浏览 10 评论
3219 浏览 3 评论
2266 浏览 5 评论
791浏览 1评论
682浏览 1评论
613浏览 1评论
686浏览 0评论
585浏览 0评论
GMT+8, 2024-12-29 18:36 , Processed in 2.039697 second(s), Total 79, Slave 63 queries .
