是德科技
李欢
7年用户 1039经验值
如何计算单个输出功率
* E4438C / E8267D-409的常见问题解答*问题:如何计算每颗卫星的单独输出功率?
以上来自于谷歌翻译
     以下为原文
  *FAQs for E4438C/E8267D-409*
Question:  How do you calculate the individual output power of each satellite?
回帖(1)
李欢
2019-4-26 10:25:49
答:ESG / PSG功率电平在卫星之间平均分配。
在有8颗卫星和ESG总输出功率P(esg)以dBm为单位的情况下,所有卫星的功率相等,单个卫星的功率为P(esg) - 9dB。
因此,如果您将ESG设置为-80 dBm,则每颗卫星均为-89 dBm
以上来自于谷歌翻译
     以下为原文
  Answer: The ESG/PSG power level is distributed equally among the satellites.  In the case where there are 8 satellites and an ESG total output power of P(esg) in dBm, with all satellites being equal power, the power of an individual satellite would be P(esg) – 9dB.  So, if you have ESG set at -80 dBm, then each satellite is at -89 dBm
