你好,
对于VDD线,100nF和10uF必须分别是陶瓷和铝吗? 此外,我们有三个使用IIS2DH构建的定制板。令人惊讶的是,当保持在相同方向时,所有三个都给出不同的XYZ值。请给我一些建议,说明我做错了什么或者我能做些什么来缓解这个问题。 谢谢, 兰芝斯 #iis2dh 以上来自于谷歌翻译 以下为原文 Hello, Is it mandatory that 100nF and 10uF to the VDD line has to be ceramic and aluminium respectively? Also, we had three custom boards built with IIS2DH. Surprisingly, all three were giving a different XYZ values when kept in the same orientation. Please give me some suggestions as to what I have done wrong or in what I could do to mitigate this problem. Thanks, Ranjith #iis2dh |
怎么不同?您是否根据均匀对齐的测试夹具中的测试保存了任何校准数据?这些部件是否平放在PCB上,方向完全相同?
您希望大容量电容具有低ESR,因此它可以在没有电阻的情况下提供瞬时电流。虽然材料/结构会影响ESR,但ESR应该是选择中使用的参数。 以上来自于谷歌翻译 以下为原文 How different? Do you save any calibration data based on testing in a uniformly aligned test fixture? Do that parts lay flat on the PCB, and exactly the same orientation? You want the bulk capacitor to have a low ESR so it can deliver instantaneous current without resistance. While the material/construction will impact the ESR, it is the ESR that should be the parameter used in the selection. |
2746 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3655 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
359浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
449浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
276浏览 2评论
GMT+8, 2024-12-28 16:35 , Processed in 0.986467 second(s), Total 48, Slave 42 queries .
