我已经编写了一些代码来发送DHCCP发现包。处理器是18F97 J60。PIC-WEB-EK板。我使用WireShark来监控数据包。问题是:如果我发送一个数据包,网络什么也看不到。如果我发送6个包,在它们之间有一个小的延迟,4个包出现。我没有得到DHCP服务器的响应,至少我可以看到。显示的数据包被WireShark识别为好的数据包。我已经检查过我的代码一百次了,但是没有找到对此的解释。我有全双工的硬件设置。状态向量没有显示错误,并且数据包被成功发送。ESTAT只显示位0设置。听起来像是某种前导问题或PHY设置的问题,但我已经看过数据表了。这就是我要重新检查的地方。我需要一些建议。
以上来自于百度翻译 以下为原文 I have written some code that sends out a dhcpdiscover packet. Processor is the 18F97j60. The PIC-WEB-EK board specifically. I am using WireShark to monitor the packets. Here's the problem: If I send a single packet the network sees nothing. If I send out 6 packets with a small delay between them 4 packets show up. I am not getting a response from the DHCP server, at least that I can see. The packets that show up are recognised by WireShark as good packets. I have gone over my code a hundred times but can find no explanation for this. I have the hardware set for full duplex. Status vectors show no errors and that the packet was sent successfully. ESTAT shows only bit 0 set. Sounds like some kind of preamble issue or something with the PHY settings but I have gone by the datasheet. Which is where I will start to double check. I need some suggestions. |
我看了用C编写的微芯片代码。我正在编写汇编代码,但是我看到的是他们每2秒发送一个DHCP发现包,直到他们得到响应。虽然这可能奏效,但它对问题没有任何启示。我的意思是,他们可能会有同样的问题,只是在周围工作,我对此表示怀疑。就我所知,它们使用相同的数据表MAC和PHY设置。
以上来自于百度翻译 以下为原文 I looked at the Microchip code, which is written in C. I am writing in assembly, but all I see is they are sending a DHCP discovery packet every 2 seconds until they get a response. While that may work, it sheds no light on the problem. I mean they could have the same issue and just be working around it, which I doubt. They use the same datasheet MAC and PHY settings as far as I can tell. |
5289 浏览 9 评论
2059 浏览 8 评论
1969 浏览 10 评论
3233 浏览 3 评论
2277 浏览 5 评论
824浏览 1评论
710浏览 1评论
654浏览 1评论
710浏览 0评论
609浏览 0评论
GMT+8, 2025-1-14 09:46 , Processed in 0.928221 second(s), Total 45, Slave 39 queries .
