电子发烧友william hill官网
你好,
我想知道当2个类型5的标签位于阅读器附近时会发生什么(例如基于X-NUCLEO-NFC05A1的阅读器)。可以同时检测2个标签吗?只会检测到最近的标签?没有检测到任何标签,因为它们会相互干扰? #multiple-devices-simultaneous#nfc05#tags-and-readers #nfc #tag-type-5 以上来自于谷歌翻译 以下为原文 Hello, I'd like to know what happen when to 2 tags of type 5 are in the vicinity of a reader ( par example a reader based on the X-NUCLEO-NFC05A1). The 2 tags can be detected simultaneously? Only the nearest tag will be detected? None of the tags will be detected because they will disturb each other? #multiple-devices-simultaneously #nfc05 #tags-and-readers #nfc #tag-type-5 |
亲爱的法布里斯,
大多数NFC标准都实施了一种称为防冲突的方法。 事实上,物理上两个标签/ VICC相互干扰,阅读器/ VCD必须检测并解决这种冲突。这样做的方法在相应的标准中描述。 有关更多详细信息,请查看ISO / IEC 15693-3:2009 - “防撞和传输协议”(第8章Anticollision)。 这种防冲突程序已经是我们的X-NUCLEO-NFC05A1软件的一部分,因此我们的演示套件可以检测附近的多个标签/ VICC。 BR Travis 以上来自于谷歌翻译 以下为原文 Dear Fabrice, Most NFC standards have a method implemented which is called anti-collision. In fact, physically two tags / VICCs are interfering with each other and the reader / VCD has to detect and solve this collision. The methodology to do so is described in the according standard. Please have a look at ISO/IEC 15693-3:2009 - 'Anticollision and transmission protocol' (chapter 8. Anticollision) for further details. This anticollision procedure is already part of our X-NUCLEO-NFC05A1 software, therfore our demo kit can detect multiple tags / VICCs in vicinity. BR Travis |
亲爱的特拉维斯,
谢谢您的回答。 我会尝试 以上来自于谷歌翻译 以下为原文 Dear Travis, Thank you for your answer. I will try it |
2746 浏览 1 评论
3244 浏览 1 评论
1813 浏览 1 评论
3655 浏览 6 评论
6044 浏览 21 评论
1342浏览 4评论
204浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
359浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
449浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
276浏览 2评论
GMT+8, 2024-12-28 15:49 , Processed in 0.647616 second(s), Total 75, Slave 59 queries .
