Introduction
The document describes a high efficiency LED driver designed to drive an LED driver at a current of 320 mA from an input voltage range of 3.6 VDC to 20 VDC, output support 2~8 series 1W LED. The XL6001 also provides a sophisticated range of protection features including output LED open faults and soft-start function. Accurate hysteretic thermal shutdown ensures safe average PCB temperatures under all conditions. Design with very low parts count. This document contains the converter specification, schematic, PCB diagram, bill of materials. Schematic XL6001 VIN=DC3.6V~DC20V, IOUT=320mA Typical Application Circuit Pin Description Pin Number Pin Name Description 1 EN Enable Pin. Drive EN pin low to turn off the device, drive it high to turn it on. Floating is default high. 2 VIN Supply Voltage Input Pin. XL6001 operates from a 3.6V to 20V DC voltage.XL6001 3 FB Feedback Pin (FB). The feedback threshold voltage is 0.22V. 4 NC No Connected.XL6001 5,6 SW Power Switch Output Pin (SW). 7,8 GND Ground Pin.XL6001 |
3074 浏览 0 评论
2109 浏览 1 评论
4649 浏览 12 评论
GMT+8, 2025-1-15 06:31 , Processed in 0.542425 second(s), Total 45, Slave 33 queries .
