采用LM386制作的微小音频放大器威廉希尔官方网站
The Tiny Audio Amplifier kit is a good choice for battery operation. It is based on LM386 IC. Power supply - 6 - 12 VDC Output power - 1 W, 8 Ohm The quiescent power drain is only 24 mW when operating from 6 VDC Self-centering output quiescent voltage Onboard PRESET to adjust volume Terminal pins for connecting power supply, audio signal and speaker Power-On LED indicator ON/OFF PCB mounted slide switch for power supply Four mounting holes of 3.2 mm each PCB dimensions 44 mm x 44 mm Parts List Inputs - Outputs configuration pcb |
GMT+8, 2024-12-26 16:08 , Processed in 2.588636 second(s), Total 72, Slave 56 queries .
