MAX车身电子高精度单向和双向电流检测放大器 MAX9918/MAX9920 这些IC为单电源、高精度电流检测放大器,具有-20V至+75V高输入共模电压范围。 MAX9921 2线霍尔效应传感器接口IC MAX25610A/MAX25610B Automotive-grade LED drivers with integrated MOSFETs and internal current sense drive up to 3A LED. MAX25611A/B/C/D 5V to 36V VIN, up to+65V boost output, support multiple configurations for front-end lighting and other LED applications. MAX25600 Provides seamless transition between buck, buck-boost, and boost modes to drive wide range of LEDs with up to 95% efficiency. |
3178 浏览 0 评论
2170 浏览 1 评论
4769 浏览 12 评论
GMT+8, 2025-3-28 18:03 , Processed in 0.350926 second(s), Total 37, Slave 28 queries .
