`BLE5.0 RSL10有双核,其中同一个为
ARM® Cortex®-M3 Processor 另一是 LPDSP32 DSP core 。
ADC参数如下:
ADC 通道:
An Analog to Digital converter (ADC), accessed by the Arm Cortex-M3 processor. The ADC can read 4 external values (DIO[0]-DIO[3]), AOUT, VDDC, VBAT/2 and the ADC offset value.
板子ADC 有串口发出:
开发板符合
Arduino所有接口标准定义。
端口示意图,CH340 USB转TTL3.3V
用keil编程,调试。
Jlink独立下载:
结果如下,显示OK
程序如下:
- * Copyright (c) 2017 Semiconductor Components Industries, LLC (d/b/a
- * ON Semiconductor), All Rights Reserved
- * This code is the property of ON Semiconductor and may not be redistributed
- * in any form without prior written permission from ON Semiconductor.
- * The terms of use and warranty for this code are covered by contractual
- * agreements between ON Semiconductor and the licensee.
- * This is Reusable Code.
- * app.c
- * - ADC UART application that measure and monitor VBAT.
- * - The value of VBAT is sent by UART to a terminal.
- * - If the value of VBAT goes lower than 1.6 V a error message is sent.
- * - As battery monitor is only on Channel 6 or 7, the ADC_CHANNEL need to 6 or
- * 7.
- * $Revision: 1.23 $
- * $Date: 2019/12/03 22:30:29 $
- #include
- #include
- #include
- * Global Variables Declaration
- volatile uint8_t data_ready_flag;
- volatile uint8_t bat_error_flag;
- volatile float adc_value;
- * Function : void ADC_BATMON_IRQHandler(void)
- * Description : Handle ADC and BATMON interrupts. When the interrupt is from
- * ADC add the ADC value to the accumulator adc_value and
- * increment the counter. When counter reach 100 calculate the
- * average and set data_ready.
- * When the interrupt is from battery monitor set bat_error.
- * Inputs : None
- * Outputs : None
- * Assumptions : None
- void ADC_BATMON_IRQHandler(void)
- static uint32_t adc_samples_count = 0;
- static uint32_t adc_filter_sum = 0.0f;
- /* Get status of ADC */
- uint32_t adc_status = Sys_ADC_Get_BATMONStatus();
- if ((adc_status & (1 << ADC_BATMON_STATUS_BATMON_ALARM_STAT_Pos)) ==
- BATMON_ALARM_TRUE)
- /* Battery monitor alarm status is set */
- bat_error_flag = 1;
- /* Clear the battery monitor status and counter */
- Sys_ADC_Clear_BATMONStatus();
- uint32_t dummy = ADC->BATMON_COUNT_VAL;
- else
- adc_filter_sum = adc_filter_sum + ADC->DATA_TRIM_CH[ADC_CHANNEL];
- adc_samples_count++;
- if (adc_samples_count == ADC_FILTER_COUNTS)
- adc_samples_count = 0;
- adc_value = (adc_filter_sum + (float)ADC_FILTER_COUNTS / 2.0f) /
- (float)ADC_FILTER_COUNTS;
- adc_filter_sum = 0;
- data_ready_flag = 1;
- * Function : void Initialize(void)
- * Description : Initialize the system by disabling interrupts, switching to
- * the 8 MHz clock (divided from the 48 MHz crystal),
- * configuring the DIOs required for the UART interface,
- * configuring ADC to measure VBAT/2, enabling battery monitor
- * and enabling interrupts.
- * Inputs : None
- * Outputs : None
- void Initialize(void)
- /* Mask all interrupts */
- __set_PRIMASK(PRIMASK_DISABLE_INTERRUPTS);
- /* Disable all existing interrupts, clearing all pending source */
- Sys_NVIC_DisableAllInt();
- Sys_NVIC_ClearAllPendingInt();
- /* Test DIO12 to pause the program to make it easy to re-flash */
- DIO->CFG[RECOVERY_DIO] = DIO_MODE_INPUT | DIO_WEAK_PULL_UP |
- DIO_LPF_DISABLE | DIO_6X_DRIVE;
- while (DIO_DATA->ALIAS[RECOVERY_DIO] == 0);
- /* Prepare the 48 MHz crystal
- * Start and configure VDDRF */
- ACS_VDDRF_CTRL->ENABLE_ALIAS = VDDRF_ENABLE_BITBAND;
- ACS_VDDRF_CTRL->CLAMP_ALIAS = VDDRF_DISABLE_HIZ_BITBAND;
- /* Wait until VDDRF supply has powered up */
- while (ACS_VDDRF_CTRL->READY_ALIAS != VDDRF_READY_BITBAND);
- /* Enable RF power switches */
- SYSCTRL_RF_POWER_CFG->RF_POWER_ALIAS = RF_POWER_ENABLE_BITBAND;
- /* Remove RF isolation */
- SYSCTRL_RF_ACCESS_CFG->RF_ACCESS_ALIAS = RF_ACCESS_ENABLE_BITBAND;
- /* Start the 48 MHz oscillator without changing the other register bits */
- RF->XTAL_CTRL = ((RF->XTAL_CTRL & ~XTAL_CTRL_DISABLE_OSCILLATOR) |
- XTAL_CTRL_REG_VALUE_SEL_INTERNAL);
- /* Enable 48 MHz oscillator divider to generate an 8 MHz clock. */
- RF_REG2F->CK_DIV_1_6_CK_DIV_1_6_BYTE = CK_DIV_1_6_PRESCALE_6_BYTE;
- /* Wait until 48 MHz oscillator is started */
- while (RF_REG39->ANALOG_INFO_CLK_DIG_READY_ALIAS !=
- ANALOG_INFO_CLK_DIG_READY_BITBAND);
- /* Switch to (divided 48 MHz) oscillator clock */
- Sys_Clocks_SystemClkConfig(JTCK_PRESCALE_1 |
- EXTCLK_PRESCALE_1 |
- SYSCLK_CLKSRC_RFCLK);
- /* Setup DIO6 as a GPIO output */
- Sys_DIO_Config(LED_DIO, DIO_MODE_GPIO_OUT_0);
- /* Initialize the UART and associated DMA */
- UART_Initialize();
- /* Set the ADC configuration */
- Sys_ADC_Set_Config(ADC_VBAT_DIV2_NORMAL | ADC_NORMAL | ADC_PRESCALE_1280H);
- /* Set the battery monitor interrupt configuration */
- Sys_ADC_Set_BATMONIntConfig(INT_EBL_ADC |
- ADC_CHANNEL <<
- ADC_BATMON_INT_ENABLE_ADC_INT_CH_NUM_Pos |
- INT_EBL_BATMON_ALARM);
- /* Set the battery monitor configuration, use channel ADC_CHANNEL to battery
- * monitoring. */
- Sys_ADC_Set_BATMONConfig((100 << ADC_BATMON_CFG_ALARM_COUNT_VALUE_Pos) |
- (THRESHOLD_CFG <<
- ADC_BATMON_CFG_SUPPLY_THRESHOLD_Pos) |
- BATMON_CH(ADC_CHANNEL));
- /* Configure ADC_CHANNEL input selection to VBAT/2 */
- Sys_ADC_InputSelectConfig(ADC_CHANNEL, ADC_POS_INPUT_VBAT_DIV2 |
- ADC_NEG_INPUT_GND);
- /* Configure both input selection for an ADC channel to GND so the OFFSET is
- * subtracted automatically to result. */
- Sys_ADC_InputSelectConfig(ADC_GND_CHANNEL, ADC_POS_INPUT_GND |
- /* Enable interrupts */
- NVIC_EnableIRQ(ADC_BATMON_IRQn);
- /* Unmask all interrupts */
- __set_PRIMASK(PRIMASK_ENABLE_INTERRUPTS);
- * Function : void Send_ADC_Value (void)
- * Description : Create a buffer with "ADC VALUE = x.xxx V" where x is the
- * ADC value read by the ADC and send it to the UART. The number
- * of digits of the mantissa is defined by NUM_DIGITS. The value
- * add to the buffer is truncated.
- * Inputs : None
- * Outputs : None
- void Send_ADC_Value(void)
- uint8_t size;
- float adc_in_volts;
- char buffer[32];
- /* Multiply by 2 as we measure VBAT/2 and divide by a gain factor to convert
- * the value from ADC. */
- adc_in_volts = (adc_value * 2.0f) / (float)ADC_GAIN;
- sprintf(buffer, "ADC input value = %.3f V
- ", adc_in_volts);
- size = strlen((const char *)buffer);
- UART_FillTXBuffer(size, (uint8_t *)buffer);
- PRINTF("ADC input value = %d mV
- ",(int32_t)(adc_in_volts * 1000));
- * Function : void Send_VBAT_Error (void)
- * Description : Create a buffer with "VBAT lower than threshold!!" and send
- * it to the UART.
- * Inputs : None
- * Outputs : None
- void Send_VBAT_Error(void)
- uint8_t size;
- const char buffer[] = "VBAT voltage lower than threshold!!
- size = strlen(buffer);
- PRINTF("VBAT voltage lower than threshold!!
- * Function : int main(void)
- * Description : Initialize the system. The ADC value is read and an average
- * of 100 values are made. When the average value is calculated
- * it's sent by UART. If a battery monitor interrupt is
- * generated an error message is sent by UART.
- * Inputs : None
- * Outputs : None
- int main(void)
- /* Initialize global variables */
- data_ready_flag = 0;
- bat_error_flag = 0;
- adc_value = 0.0f;
- /* Initialize the system */
- Initialize();
- PRINTF("DEVICE INITIALIZED
- /* Spin loop */
- while (1)
- /* Refresh the watch-dog timer */
- Sys_Watchdog_Refresh();
- if (data_ready_flag == 1)
- Send_ADC_Value();
- if (bat_error_flag == 1)
- Send_VBAT_Error();
