如若平台没有留有本公司咨询方式,请在浏览器搜索东莞市塘厦佳华电子仪器经营部 欢迎广大朋友前来咨询 上门回收工厂闲置/倒闭电子仪器,个人处理仪器,欢迎您的来电!! 赵经理:188~~~8361~~~1172 企 鹅:25722~~38817 地址:东莞市塘厦镇莲湖怡景路8号 安捷伦E4419A功率计出售E4419A维修安捷伦E4419A租赁 E4419A EPM Series Dual-Channel Power Meter 描述 The Keysight E4419A is a low-cost, high-performance, dual-channel, programmable power meter. It is fully compatible with the 8480 series of power sensors and the E-series of power sensors (except the E9320A Family). Depending upon which sensor is used, the E4419A can measure from -70 dBm to +44 dBm at frequencies from 100 kHz to 110 GHz. Designed for bench and automatic test equipment use (ATE), the E4419A makes fast (up to 100 readings per second with E-series sensors), accurate and repeatable power measurements. The E4419A is a true dual-channel power meter, which means that you get two simultaneous power readings on the display. · Fast measurement speed (up to 100 readings per second, over the GPIB, with E-series sensors) · Speed improvement of x2 using the 8480 series power sensor (compared to 437B) · No range-switching delays with 8480 series sensors, and only one fast-range switching point with E-series sensors · High-resolution display with backlighting for a wide viewing angle of displayed data · Save and recall of up to 10 instrument states · GPIB connector for remote control of all functions · Code compatibility with 438A · Conformity to CE and CSA standards · For complete details click on the Data Sheet link · For extensive self-help resources, see Frequently Asked Questions (FAQs) ` |
3058 浏览 0 评论
2092 浏览 1 评论
4611 浏览 12 评论
GMT+8, 2024-12-29 01:42 , Processed in 0.318554 second(s), Total 35, Slave 27 queries .
