/*24C02-多花样流水灯演示程序(C51)
/* 将演示数据先写入24C02芯片内,再将其数据逐个读出送P0口LED显示。
#include
#include
#define uchar unsigned char
#define uint unsigned int
#define OP_WRITE 0xa0 // 器件地址以及写入操作
#define OP_READ 0xa1 // 器件地址以及读取操作
uchar code display[72]={
0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F,
0xBF,0xDF,0xEF,0xF7,0xFB,0xFD,0xFE,0xFF,
0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00,
0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF,
0xFC,0xF9,0xF3,0xE7,0xCF,0x9F,0x3F,
0x9F,0xCF,0xE7,0xF3,0xF9,0xFC,0xFF,
0xE7,0xDB,0xBD,0x7E,0xBD,0xDB,0xE7,0xFF,
0xE7,0xC3,0x81,0x00,0x81,0xC3,0xE7,0xFF,
0xAA,0x55,0x18,0xFF,0xF0,0x0F,
0x00,0xFF,0x00,0xFF };
***it SDA = P3^5;
***it SCL = P3^4;
void start();
void stop();
uchar shin();
bit shout(uchar write_data);
void write_byte( uchar addr, uchar write_data);
void fill_byte(uchar fill_size,uchar fill_data);
void delayms(uint ms);
uchar read_current();
uchar read_random(uchar random_addr);
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
main(void)
uchar i;
SDA = 1;
SCL = 1;
fill_byte(72,0xff); // 将前72字节填充0xff
for(i = 0 ; i < 72; i++) //写入显示代码到AT24C02
write_byte(i,display);
for(i =0 ;i <72 ; i++) //从AT24C02移出数据送到P0口显示
P0 = read_random(i);
delayms(350);
void start()
//开始位
SDA = 1;
SCL = 1;
delayNOP();
SDA = 0;
delayNOP();
SCL = 0;
void stop()
// 停止位
SDA = 0;
delayNOP();
SCL = 1;
delayNOP();
SDA = 1;
uchar shin()
// 从AT24C02移出数据到MCU
uchar i,read_data;
for(i = 0; i < 8; i++)
SCL = 1;
read_data <<= 1;
read_data |= SDA;
SCL = 0;
return(read_data);
// 从MCU移出数据到AT24C02
uchar i;
bit ack_bit;
for(i = 0; i < 8; i++) // 循环移入8个位
SDA = (bit)(write_data & 0x80);
_nop_();
SCL = 1;
delayNOP();
SCL = 0;
write_data <<= 1;
SDA = 1; // 读取应答
delayNOP();
SCL = 1;
delayNOP();
ack_bit = SDA;
SCL = 0;
return ack_bit; // 返回AT24C02应答位
void write_byte(uchar addr, uchar write_data)
// 在指定地址addr处写入数据write_data
start();
shout(OP_WRITE);
shout(addr);
shout(write_data);
stop();
delayms(10); // 写入周期
// 填充数据fill_data到EEPROM内fill_size字节
uchar i;
for(i = 0; i < fill_size; i++)
write_byte(i, fill_data);
// 在当前地址读取
uchar read_data;
start();
shout(OP_READ);
read_data = shin();
stop();
return read_data;
// 在指定地址读取
start();
shout(OP_WRITE);
shout(random_addr);
return(read_current());
// 延时子程序
uchar k;
while(ms--)
for(k = 0; k < 120; k++);
本文来自电子工程师之家
