做蒙地卡罗分析需要调用带有统计分布参数的器件模型,如果找不到统计分析需要的参数,仿真就回报这样的错。如果是tsmc的工艺的话,建议在schematic中改用带有MC参数的器件,然后重新产生netlist.
HIi, dear
i use TSMC PDK, for monte carlo analysis , first you must use mismatch model for example MOS2_mis for your PDK. after that you must change library type. go to the model lib from ADE and Change all corner process to to mc and run your analysis. |
792个成员聚集在这个小组
加入小组5010 浏览 0 评论
3821 浏览 0 评论
4731 浏览 0 评论
3761 浏览 0 评论
7507 浏览 0 评论
GMT+8, 2024-12-30 02:18 , Processed in 0.674910 second(s), Total 79, Slave 60 queries .
