ADC 读取芯片内部温度传感器的方法
static void AdcSetup(void) { // Enable ADC clock CMU_ClockEnable(cmuClock_ADC0, true); ADC_Init_TypeDef init = ADC_INIT_DEFAULT; ADC_InitSingle_TypeDef sInit = ADC_INITSINGLE_DEFAULT; init.timebase = ADC_TimebaseCalc(0); init.prescale = ADC_PrescaleCalc(400000, 0); ADC_Init(ADC0, &init); //Set input to temperature sensor. Reference must be 1.25V sInit.reference = adcRef1V25; sInit.acqTime = adcAcqTime8; /* Minimum time for temperature sensor */ sInit.posSel = adcPosSelTEMP; ADC_InitSingle(ADC0, &sInit); } static uint32_t AdcRead(void) { ADC_Start(ADC0, adcStartSingle); while ( (ADC0-》STATUS & ADC_STATUS_SINGLEDV) == 0 ) { } return ADC_DataSingleGet(ADC0); } static float ConvertToCelsius(int32_t adcSample) { uint32_t calTemp0; uint32_t calValue0; int32_t readDiff; float temp; //Factory calibration temperature from device information page. calTemp0 = ((DEVINFO-》CAL & _DEVINFO_CAL_TEMP_MASK) 》》 _DEVINFO_CAL_TEMP_SHIFT); calValue0 = ((DEVINFO-》ADC0CAL3 /* _DEVINFO_ADC0CAL3_TEMPREAD1V25_MASK is not correct in current CMSIS. This is a 12-bit value, not 16-bit. */ & 0xFFF0) 》》 _DEVINFO_ADC0CAL3_TEMPREAD1V25_SHIFT); if ((calTemp0 == 0xFF) || (calValue0 == 0xFFF)) { //The temperature sensor is not calibrated return -100.0; } //Vref = 1250mV TGRAD_ADCTH = 1.84 mV/degC (from datasheet) readDiff = calValue0 - adcSample; temp = ((float)readDiff * 1250); temp /= (4096 * -1.84); //Calculate offset from calibration temperature temp = (float)calTemp0 - temp; return temp * 100; } void customWriteAttributeEventHandler() { int32_t sample = 0; int16_t temp = 0; emberEventControlSetInactive(customWriteAttributeEventData); sample = AdcRead(); temp = ConvertToCelsius(sample); emberAfCorePrintln(“sample=%d”, sample); emberAfCorePrintln(“temp=%d”, temp); emberAfWriteServerAttribute(1, ZCL_TEMP_MEASUREMENT_CLUSTER_ID, ZCL_TEMP_MEASURED_VALUE_ATTRIBUTE_ID, &temp, ZCL_INT16S_ATTRIBUTE_TYPE); emberEventControlSetDelayMS(customWriteAttributeEventData, 30000); } 使用温度传感器,或温湿度传感器读取温度 单总线读取温度数据 void dht_Rst(void) { dht_IO_OUT(); dht_data_OUT_0; nrf_delay_ms(25); dht_data_OUT_1; dht_data_OUT_1; nrf_delay_us(30); } u8 dht_Check(void) { u8 time=0; dht_IO_IN();//SET INPUT while (dht_data_IN&&time《100) { time++; nrf_delay_us(1); } if(time》=100) { printf(“errorrn”); return 1; } else time=0; while (!dht_data_IN&&time《100) { time++; nrf_delay_us(1); } if(time》=100) { printf(“error 2rn”); return 1; } return 0; } u8 dht_Read_Bit(void) { u8 time=0; while(dht_data_IN&&time《100) { time++; nrf_delay_us(1); } time=0; while(!dht_data_IN&&time《100) { time++; nrf_delay_us(1); } nrf_delay_us(40); if(dht_data_IN)return 1; else return 0; } u8 dht_Read_Byte(void) { u8 i,dat; dat=0; for (i=0;i《8;i++) { dat《《=1; dat|=dht_Read_Bit(); } return dat; } u8 dht_Read_Data(u8 *temp,u8 *humi) { u8 dat[5]; u8 i; dht_Rst(); if(dht_Check()==0) { for(i=0;i《5;i++) { dat[i]=dht_Read_Byte(); } if((dat[0]+dat[1]+dat[2]+dat[3])==dat[4]) { *humi=dat[0]; *temp=dat[2]; } } else { return 1; } return 0; } u8 dht_Init(void) { dht_Rst(); return dht_Check(); } |
4626个成员聚集在这个小组
加入小组3363 浏览 0 评论
4288 浏览 1 评论
4317 浏览 0 评论
GMT+8, 2025-1-13 21:27 , Processed in 0.533195 second(s), Total 73, Slave 57 queries .
