首先下载 stlink 的 Linux 版本,下载地址。
然后解压到你指定的路径下,参照其中的 README 文件进行配置编译。
HOWTO
First, you have to know there are several boards supported by the software.
Those boards use a chip to translate from USB to JTAG commands. The chip is
called stlink and there are 2 versions:
。 STLINKv1, present on STM32VL discovery kits,
。 STLINKv2, present on STM32L discovery and later kits.
2 different transport layers are used:
。 STLINKv1 uses SCSI passthru commands over USB,
。 STLINKv2 uses raw USB commands.
Common requirements(依赖环境)
。 libu***-1.0 (You probably already have this, but you‘ll need the
development version to compile)
(这个工具只需要执行sudo apt-get install libu***-dev && sudo apt-get install libu***-1.0-0-dev这两个命令即可。)
。 pkg-config
(这个工具一般Ubuntu都会默认安装,注意变量PKG-CONFIG-PATH的设置)
IF YOU HAVE AN STLINKv1
The STLINKv1’s SCSI emulation is very broken, so the best thing to do
is tell your operating system to completely ignore it.
Options (do one of these before you plug it in)
*) modprobe -r u***-storage && modprobe u***-storage quirks=483:3744:i
or *)1. add “options u***-storage quirks=483:3744:i” to /etc/modprobe.conf
*)2. modprobe -r u***-storage && modprobe u***-storage
or *)1. cp stlink_v1.modprobe.conf /etc/modprobe.d
IF YOU HAVE AN STLINKv2(我们的开发板支持STLINKv2,所以这里不做配置)
You‘re ready to go :)
COMPILING(编译:下边3个指令即可)
This project was converted to Autotools by a well meaning individual. The
following steps will build the project for you.
$ 。/autogen.sh
$ 。/configure
$ make
USING THE GDBSERVER(使用GDB调试服务)
To run the gdb server: (you do not need sudo if you have set up
permissions correctly)
(此时连上你的开发板,一般都要sudo)
$ make && [sudo] 。/st-util
There are a few options:
。/st-util - usage:
-h, --help Print this help
-vXX, --verbose=XX Specify a specific verbosity level (0..99)
-v, --verbose Specify generally verbose logging
-s X, --stlink_version=X
Choose what version of stlink to use, (defaults to 2)
-1, --stlinkv1 Force stlink version 1
-p 4242, --listen_port=1234
Set the gdb server listen port. (default port: 4242)
-m, --multi
Set gdb server to extended mode.
st-util will continue listening for connections after disconnect.
-n, --no-reset
Do not reset board on connection.
The STLINKv2 device to use can be specified in the environment
variable STLINK_DEVICE on the format 《USB_BUS》:《USB_ADDR》。
Then, in your project directory, someting like this.。.
(remember, you need to run an _ARM_ gdb, not an x86 gdb)
(重新打开一个终端,找到你编译好的应用程序的目录,就是存在elf文件的地方)
$ arm-none-eabi-gdb fancyblink.elf (开启调试)
(gdb) tar extended-remote :4242 (连上GDB服务)
(gdb) load
Loading section .text, size 0x458 lma 0x8000000
Loading section .data, size 0x8 lma 0x8000458
Start address 0x80001c1, load size 1120
Transfer rate: 1 KB/sec, 560 bytes/write.
(gdb)
(gdb) continue
Have fun!
Resetting the chip from GDB
You may reset the chip using GDB if you want. You’ll need to use `target
extended-remote‘ command like in this session:
(gdb) target extended-remote localhost:4242
Remote debugging using localhost:4242
0x080007a8 in _startup ()
(gdb) kill
Kill the program being debugged? (y or n) y
(gdb) run
Starting program: /home/whitequark/ST/apps/bally/firmware.elf
Remember that you can shorten the commands. `tar ext :4242’ is good enough
for GDB.
Setting up udev rules
For convenience, you may install udev rules file, 49-stlinkv*.rules, located
in the root of repository. You will need to copy it to /etc/udev/rules.d,
and then either reboot or execute
$ udevadm control --reload-rules
$ udevadm trigger
Udev will now create a /dev/stlinkv2_XX or /dev/stlinkv1_XX file, with the appropriate permissions.
This is currently all the device is for, (only one stlink of each version is supported at
any time presently)
Running programs from SRAM(在RAM上运行)
You can run your firmware directly from SRAM if you want to. Just link
it at 0x20000000 and do
(gdb) load firmware.elf
It will be loaded, and pc will be adjusted to point to start of the
code, if it is linked correctly (i.e. ELF has correct entry point)。
Writing to flash(烧写Flash)
The GDB stub ships with a correct memory map, including the flash area.
If you would link your executable to 0x08000000 and then do
then it would be written to the memory.
FAQ
Q: My breakpoints do not work at all or only work once.
A: Optimizations can cause severe instruction reordering. For example,
if you are doing something like `REG = 0x100;‘ in a loop, the code may
be split into two parts: loading 0x100 into some intermediate register
and moving that value to REG. When you set up a breakpoint, GDB will
hook to the first instruction, which may be called only once if there are
enough unused registers. In my experience, -O3 causes that frequently.
Q: At some point I use GDB command `next’, and it hangs.
A: Sometimes when you will try to use GDB `next‘ command to skip a loop,
it will use a rather inefficient single-stepping way of doing that.
Set up a breakpoint manually in that case and do `continue’。
Currently known working combinations of programmer and target
STLink v1 (as found on the 32VL Discovery board)
Known Working Targets:
* STM32F100xx (Medium Density VL)
* STM32F103 (according to jpa- on ##stm32)
No information:
* everything else!
STLink v2 (as found on the 32L and F4 Discovery boards)
* STM32F0Discovery (STM32F0 Discovery board)
* STM32F100xx (Medium Density VL, as on the 32VL Discovery board)
* STM32L1xx (STM32L Discovery board)
* STM32F103VC, STM32F107RC, STM32L151RB, STM32F205RE and STM32F405RE on custom boards
(https://github.com/UweBonnes/wiki_fuer_alex/layout/usps.。.)
* STM32F303xx (STM32F3 Discovery board)
* STM32F407xx (STM32F4 Discovery board)
* STM32F429I-DISCO (STM32F4 Discovery board with LCD)
* STM32F439VIT6 (discovery board reseated CPU)
* STM32L151CB (custom board)
* STM32L152RB (STM32L-Discovery board, custom board)
STLink v2-1 (as found on the Nucleo boards)
* STM32F401xx (STM32 Nucleo-F401RE board)
Please report any and all known working combinations so I can update this!
按照上边步骤的配置,就可以调试和下载应用程序。
HOWTO
。 pkg-config
$ 。/autogen.sh
$ 。/configure
$ make
。/st-util - usage:
-m, --multi
-n, --no-reset
(gdb) load
(gdb)
(gdb) continue
Have fun!
(gdb) kill
(gdb) run
for GDB.
$ udevadm trigger
any time presently)
FAQ
No information:
* everything else!
