1.
电量检测用SARADC_ANI0通道,platform_device代码在 arch/arm/mach-rk30/devices.c 中: struct platform_device device_adc = { .name = "rk30-adc", .id = -1, .num_resources = ARRAY_SIZE(rk30_adc_resource), .resource = rk30_adc_resource, .dev = { .platform_data = &rk30_adc_pdata, }, }; platform_driver代码在drivers/adc/plat/rk30_adc.c 中,实现了start, stop, read函数; 接着电量检测上报代码在power/rk30_factory_adc_battery.c中,注册到drivers/adc/core.c中,通过回调start, read等进行电量的读取上报动作; 上层system/core/charger/charger.c 中检测上报的事件,如果全部offline或者超时则会重启机子。 power上报机制: drivers/power/power_supply_core.c power_supply_register函数中 [cpp] view plain copy dev->class = power_supply_class; dev->type = &power_supply_dev_type; dev->parent = parent; dev->release = power_supply_dev_release; dev_set_drvdata(dev, psy); psy->dev = dev; 主要是为 dev->type和psy->dev赋值,并且power_supply_class_init函数中: [cpp] view plain copy power_supply_class->dev_uevent = power_supply_uevent; 使得后续kobject_uevent上报的是power_supply_uevent的内容,位于 drivers/power/power_supply_sysfs.c中; 在上层cat时候显示的则为power_supply_sysfs.c中 [cpp] view plain copy #define POWER_SUPPLY_ATTR(_name) { .attr = { .name = #_name }, .show = power_supply_show_property, .store = power_supply_store_property, } 所定义的内容。 2. 3G 3G唤醒主机原理: 在3G中断到来时候调用wake_lock_timeout(&bp->bp_wakelock, 10 * HZ); 上层会保持不休眠 平台的gpio定义在board-rk3188-rk616-3gonlydataABC.c 中: static int mu509_io_deinit(void) { return 0; } struct rk29_mu509_data rk29_mu509_info = { .io_init = mu509_io_init, .io_deinit = mu509_io_deinit, .modem_power_en = RK30_PIN0_PC6, .bp_power = RK30_PIN2_PD5, .bp_reset = RK30_PIN0_PB4, .ap_wakeup_bp = RK30_PIN0_PC4, .bp_wakeup_ap = RK30_PIN0_PC5, }; struct platform_device rk29_device_mu509 = { .name = "mu509", .id = -1, .dev = { .platform_data = &rk29_mu509_info, } }; GPIO逻辑控制代码在kernel/drivers/misc/bp/chips中 3. 编译步骤 kernel: cd kernel; make ARCH=arm rk3188_ABC_3gonlydata_defconfig menuconfig make ARCH=arm rk3188_ABC_3gonlydata_defconfig make kernel.img android: A. 高清屏需要配置:vim device/rockchip/rk30sdk/BoardConfig.mk将下面两个宏改为 true BOARD_USE_LCDC_COMPOSER := true BOARD_LCDC_COMPOSER_LANDSCAPE_ONLY := true B. 执行 make C. 执行./mkimage.sh 即可在 rockdev/Image 目录下生成以下 4 个 img system.img boot.img recovery.img misc.img 4. wifi-bt模块AP6210 看/sys/class/rkwifi节点有没有出来,接着cat /sys/class/rkwifi/chip看芯片型号对不对,这部分的实现代码在kernel/drivers/net/wireless/wifi_sys/rkwifi_sys_iface.c中。 照着RK的文档配置好了WIFI,log提示没有问题,点击后界面一直提示正在搜索网络,但是一直没有结果出来。原来是由于kernel中WIFI模块晶振配置不正确,应该为26M,却是配置成了24M。修改完成重烧kernel后启动,马上搜索到网络了 bt打开马上关闭,提示如下log: D/AudioHardware( 108): AudioHardware pcm playback is exiting standby. D/AudioHardware( 108): openPcmOut_l() mPcmOpenCnt: 0 D/alsa_pcm( 108): pcm_open(0x0003f000) D/alsa_pcm( 108): pcm_open() period sz multiplier 16 D/alsa_pcm( 108): pcm_open() period cnt 6 D/alsa_pcm( 108): pcm_open() period_cnt 6 period_sz 1024 channels 2 I/alsa_mix( 108): -->Playback Path access 3 D/BluetoothManagerService( 362): enable(): mBluetooth =android.bluetooth.IBluetooth$Stub$Proxy@413b1880 mBinding = false D/BluetoothManagerService( 362): Message: MESSAGE_ENABLE D/BluetoothManagerService( 362): MESSAGE_ENABLE: mBluetooth = android.bluetooth.IBluetooth$Stub$Proxy@413b1880 D/BluetoothAdapterService( 810): Broadcasting updateAdapterState() to 1 receivers. D/BluetoothBondStateMachine( 810): make D/BluetoothManagerService( 362): Message: MESSAGE_BLUETOOTH_STATE_CHANGE D/BluetoothManagerService( 362): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 10, newState=11 D/BluetoothManagerService( 362): Bluetooth State Change Intent: 10 -> 11 I/bluedroid( 810): enable D/BTIF_CORE( 810): not disabled E/BluetoothAdapterState( 810): Error while turning Bluetooth On D/BluetoothAdapterService( 810): Broadcasting updateAdapterState() to 1 receivers. I/BluetoothBondStateMachine( 810): StableState(): Entering Off State D/BluetoothManagerService( 362): Message: MESSAGE_BLUETOOTH_STATE_CHANGE D/BluetoothManagerService( 362): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 11, newState=10 D/BluetoothManagerService( 362): Broadcasting onBluetoothStateChange(false) to 7 receivers. D/BluetoothHeadset( 591): onBluetoothStateChange: up=false E/BluetoothHeadset( 591): E/BluetoothHeadset( 591): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadset$2@410d4f70 E/BluetoothHeadset( 591): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:921) E/BluetoothHeadset( 591): at android.app.ContextImpl.unbindService(ContextImpl.java:1460) E/BluetoothHeadset( 591): at android.content.ContextWrapper.unbindService(ContextWrapper.java:484) E/BluetoothHeadset( 591): at android.bluetooth.BluetoothHeadset$1.onBluetoothStateChange(BluetoothHeadset.java:234) E/BluetoothHeadset( 591): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55) E/BluetoothHeadset( 591): at android.os.Binder.execTransact(Binder.java:351) E/BluetoothHeadset( 591): at dalvik.system.NativeStart.run(Native Method) D/BluetoothA2dp( 362): onBluetoothStateChange: up=false D/BluetoothAdapterService(1091175776)( 810): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@410a1ea0 E/BluetoothA2dp( 362): E/BluetoothA2dp( 362): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothA2dp$2@413f3418 E/BluetoothA2dp( 362): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:921) E/BluetoothA2dp( 362): at android.app.ContextImpl.unbindService(ContextImpl.java:1460) E/BluetoothA2dp( 362): at android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange(BluetoothA2dp.java:121) E/BluetoothA2dp( 362): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:575) E/BluetoothA2dp( 362): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1189) E/BluetoothA2dp( 362): at com.android.server.BluetoothManagerService.access$3000(BluetoothManagerService.java:47) E/BluetoothA2dp( 362): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:941) E/BluetoothA2dp( 362): at android.os.Handler.dispatchMessage(Handler.java:99) E/BluetoothA2dp( 362): at android.os.Looper.loop(Looper.java:137) E/BluetoothA2dp( 362): at android.os.HandlerThread.run(HandlerThread.java:60) E/BluetoothPan( 516): E/BluetoothPan( 516): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPan$2@410ab038 E/BluetoothPan( 516): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:921) E/BluetoothPan( 516): at android.app.ContextImpl.unbindService(ContextImpl.java:1460) E/BluetoothPan( 516): at android.content.ContextWrapper.unbindService(ContextWrapper.java:484) E/BluetoothPan( 516): at android.bluetooth.BluetoothPan$1.onBluetoothStateChange(BluetoothPan.java:183) E/BluetoothPan( 516): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55) E/BluetoothPan( 516): at android.os.Binder.execTransact(Binder.java:351) E/BluetoothPan( 516): at dalvik.system.NativeStart.run(Native Method) D/BluetoothInputDevice( 516): onBluetoothStateChange: up=false E/BluetoothInputDevice( 516): E/BluetoothInputDevice( 516): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothInputDevice$2@410a5b68 E/BluetoothInputDevice( 516): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:921) E/BluetoothInputDevice( 516): at android.app.ContextImpl.unbindService(ContextImpl.java:1460) E/BluetoothInputDevice( 516): at android.content.ContextWrapper.unbindService(ContextWrapper.java:484) E/BluetoothInputDevice( 516): at android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange(BluetoothInputDevice.java:199) E/BluetoothInputDevice( 516): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55) E/BluetoothInputDevice( 516): at android.os.Binder.execTransact(Binder.java:351) E/BluetoothInputDevice( 516): at dalvik.system.NativeStart.run(Native Method) D/BluetoothHeadset( 362): onBluetoothStateChange: up=false D/BluetoothAdapterService(1091175776)( 810): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@410a1ea0 E/BluetoothHeadset( 362): E/BluetoothHeadset( 362): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadset$2@41249b68 E/BluetoothHeadset( 362): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:921) E/BluetoothHeadset( 362): at android.app.ContextImpl.unbindService(ContextImpl.java:1460) E/BluetoothHeadset( 362): at android.bluetooth.BluetoothHeadset$1.onBluetoothStateChange(BluetoothHeadset.java:234) E/BluetoothHeadset( 362): at com.android.server.BluetoothManagerService.sendBluetoothStateCallback(BluetoothManagerService.java:575) E/BluetoothHeadset( 362): at com.android.server.BluetoothManagerService.bluetoothStateChangeHandler(BluetoothManagerService.java:1189) E/BluetoothHeadset( 362): at com.android.server.BluetoothManagerService.access$3000(BluetoothManagerService.java:47) E/BluetoothHeadset( 362): at com.android.server.BluetoothManagerService$BluetoothHandler.handleMessage(BluetoothManagerService.java:941) E/BluetoothHeadset( 362): at android.os.Handler.dispatchMessage(Handler.java:99) E/BluetoothHeadset( 362): at android.os.Looper.loop(Looper.java:137) E/BluetoothHeadset( 362): at android.os.HandlerThread.run(HandlerThread.java:60) D/BluetoothHeadset( 591): onBluetoothStateChange: up=false E/BluetoothHeadset( 591): E/BluetoothHeadset( 591): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothHeadset$2@410ac518 E/BluetoothHeadset( 591): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:921) E/BluetoothHeadset( 591): at android.app.ContextImpl.unbindService(ContextImpl.java:1460) E/BluetoothHeadset( 591): at android.content.ContextWrapper.unbindService(ContextWrapper.java:484) E/BluetoothHeadset( 591): at android.bluetooth.BluetoothHeadset$1.onBluetoothStateChange(BluetoothHeadset.java:234) E/BluetoothHeadset( 591): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55) E/BluetoothHeadset( 591): at android.os.Binder.execTransact(Binder.java:351) E/BluetoothHeadset( 591): at dalvik.system.NativeStart.run(Native Method) D/BluetoothPbap( 516): onBluetoothStateChange: up=false E/BluetoothPbap( 516): E/BluetoothPbap( 516): java.lang.IllegalArgumentException: Service not registered: android.bluetooth.BluetoothPbap$2@410b0368 E/BluetoothPbap( 516): at android.app.LoadedApk.forgetServiceDispatcher(LoadedApk.java:921) E/BluetoothPbap( 516): at android.app.ContextImpl.unbindService(ContextImpl.java:1460) E/BluetoothPbap( 516): at android.content.ContextWrapper.unbindService(ContextWrapper.java:484) E/BluetoothPbap( 516): at android.bluetooth.BluetoothPbap$1.onBluetoothStateChange(BluetoothPbap.java:122) E/BluetoothPbap( 516): at android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact(IBluetoothStateChangeCallback.java:55) E/BluetoothPbap( 516): at android.os.Binder.execTransact(Binder.java:351) E/BluetoothPbap( 516): at dalvik.system.NativeStart.run(Native Method) D/BluetoothManagerService( 362): Bluetooth State Change Intent: 11 -> 10 D/BluetoothAdapterService(1091175776)( 810): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@410a1ea0 D/BluetoothAdapterService(1091175776)( 810): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@410a1ea0 D/BluetoothAdapterService(1091175776)( 810): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@410a1ea0 D/BluetoothAdapterService(1091175776)( 810): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@410a1ea0 D/BluetoothAdapterService(1091175776)( 810): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@410a1ea0 D/BluetoothAdapterService(1091175776)( 810): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@410a1ea0 D/BluetoothAdapterService(1091175776)( 810): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@410a1ea0 D/dalvikvm( 516): GC_CONCURRENT freed 438K, 15% free 4671K/5476K, paused 2ms+4ms, total 28ms W/ContextImpl( 516): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1361 android.content.ContextWrapper.startService:450 android.content.ContextWrapper.startService:450 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115 D/DockEventReceiver( 516): finishStartingService: stopping service D/BluetoothAdapterService(1091175776)( 810): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@410a1ea0 D/AudioHardware( 108): AudioHardware pcm playback is going to standby. I/alsa_mix( 108): -->Playback Path access 3 D/AudioHardware( 108): closePcmOut_l() mPcmOpenCnt: 1 原因,kernel/net/rfkill/rfkill-rk.c 中是控制BT GPIO的驱动,由于二合一模块共用一个电源,WIFI已经打开了模块电源,BT时候又申请该GPIO去控制电源,导致直接返回,没有往下执行其他动作,把BT的电源控制GPIO去掉即可,成功的LOG如下: D/BluetoothManagerService( 364): enable(): mBluetooth =null mBinding = false D/BluetoothManagerService( 364): Message: MESSAGE_ENABLE D/BluetoothManagerService( 364): MESSAGE_ENABLE: mBluetooth = null D/BluetoothAdapterService( 802): REFCOUNT: CREATED. INSTANCE_COUNT2 D/BluetoothAdapterState( 802): make I/bluedroid( 802): init I/bte_conf( 802): Attempt to load stack conf from /etc/bluetooth/bt_stack.conf I/bluedroid( 802): get_profile_interface socket I/GKI_LINUX( 802): gki_task_entry: gki_task_entry task_id=1 [BTIF] starting D/BluetoothManagerService( 364): BluetoothServiceConnection: connected to AdapterService D/BluetoothManagerService( 364): Message: MESSAGE_BLUETOOTH_SERVICE_CONNECTED D/BluetoothManagerService( 364): MESSAGE_BLUETOOTH_SERVICE_CONNECTED D/BluetoothManagerService( 364): Calling onBluetoothServiceUp callbacks D/BluetoothManagerService( 364): Broadcasting onBluetoothServiceUp() to 5 receivers. D/BluetoothAdapter( 441): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@436b8cc0 D/BluetoothAdapter( 703): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@42369fa0 D/BluetoothAdapter( 546): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@42268250 D/BluetoothManagerService( 364): Bluetooth Adapter name changed to ABC D/BluetoothManagerService( 364): Stored Bluetooth name: ABC D/BluetoothAdapter( 364): onBluetoothServiceUp: android.bluetooth.IBluetooth$Stub$Proxy@426800e0 D/BluetoothAdapter( 802): onBluetoothServiceUp: com.android.bluetooth.btservice.AdapterService$AdapterServiceBinder@4228f608 D/BluetoothAdapterService( 802): Broadcasting updateAdapterState() to 1 receivers. D/BluetoothBondStateMachine( 802): make D/BluetoothManagerService( 364): Message: MESSAGE_BLUETOOTH_STATE_CHANGE D/BluetoothManagerService( 364): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 10, newState=11 D/BluetoothManagerService( 364): Bluetooth State Change Intent: 10 -> 11 I/BluetoothBondStateMachine( 802): StableState(): Entering Off State D/BluetoothAdapterService(1109812520)( 802): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@4228f650 D/HeadsetService( 802): Received start request. Starting profile... D/HeadsetStateMachine( 802): make I/bluedroid( 802): get_profile_interface handsfree E/bt-btif ( 802): btif_enable_service: current services:0x100040 D/A2dpService( 802): Received start request. Starting profile... D/A2dpStateMachine( 802): make I/bluedroid( 802): get_profile_interface a2dp I/GKI_LINUX( 802): gki_task_entry: gki_task_entry task_id=2 [A2DP-MEDIA] starting E/bt-btif ( 802): btif_enable_service: current services:0x140040 D/A2dpStateMachine( 802): Enter Disconnected: -2 D/HidService( 802): Received start request. Starting profile... |
I/bluedroid( 802): get_profile_interface hidhost
E/bt-btif ( 802): btif_enable_service: current services:0x140040 D/BluetoothAdapterService( 802): Profile still not running:com.android.bluetooth.hdp.HealthService D/HeadsetPhoneState( 802): sendDeviceStateChanged. mService=0 mSignal=0 mRoam=0 mBatteryCharge=4 D/HealthService( 802): Received start request. Starting profile... I/bluedroid( 802): get_profile_interface health D/BluetoothAdapterService( 802): Profile still not running:com.android.bluetooth.hdp.HealthService D/BluetoothAdapterService( 802): Profile still not running:com.android.bluetooth.hdp.HealthService D/PanService( 802): Received start request. Starting profile... D/BluetoothPanServiceJni( 802): initializeNative(L110): pan I/bluedroid( 802): get_profile_interface pan D/BluetoothAdapterService( 802): Profile still not running:com.android.bluetooth.pan.PanService I/bluedroid( 802): enable I/bt_hci_bdroid( 802): init I/bt_vendor( 802): init I/bt_vnd_conf( 802): Attempt to load conf from /etc/bluetooth/bt_vendor.conf I/bt_vnd_conf( 802): vnd_load_conf file >/etc/bluetooth/bt_vendor.conf< not found D/bt_vendor( 802): op for 5 I/bt_hci_bdroid( 802): bt_hc_worker_thread started D/bt_vendor( 802): op for 0 D/bt_upio ( 802): is_emulator_context : 0 D/bt_upio ( 802): is_rfkill_disabled ? [0] D/bt_upio ( 802): Delay 500ms for bluetooth power up D/bt_vendor( 802): op for 0 D/bt_upio ( 802): is_emulator_context : 0 D/bt_upio ( 802): is_rfkill_disabled ? [0] D/bt_upio ( 802): Delay 500ms for bluetooth power up D/bt_vendor( 802): op for 3 I/bt_userial_vendor( 802): userial vendor open: opening /dev/ttyS0 I/bt_userial_vendor( 802): device fd = 79 open I/GKI_LINUX( 802): gki_task_entry: gki_task_entry task_id=0 [BTU] starting D/bt_vendor( 802): op for 1 I/bt_hwcfg( 802): bt vendor lib: set UART baud 1500000 D/bt_hwcfg( 802): Chipset BCM20702A D/bt_hwcfg( 802): Target name = [BCM20702A] I/bt_hwcfg( 802): BT module name is: ap6210 I/bt_hwcfg( 802): Target HCD file name is: bcm20710a1.hcd I/bt_hwcfg( 802): Found patchfile: /vendor/firmware//bcm20710a1.hcd I/bt_hwcfg( 802): bt vendor lib: set UART baud 115200 D/bt_hwcfg( 802): Settlement delay -- 100 ms I/bt_hwcfg( 802): bt vendor lib: set UART baud 1500000 I/bt_hwcfg( 802): Setting local bd addr to 54:04:05:C1:02:FE I/bt_hwcfg( 802): vendor lib fwcfg completed I/ ( 802): BTE_InitTraceLevels -- TRC_HCI I/ ( 802): BTE_InitTraceLevels -- TRC_L2CAP I/ ( 802): BTE_InitTraceLevels -- TRC_RFCOMM I/ ( 802): BTE_InitTraceLevels -- TRC_AVDT I/ ( 802): BTE_InitTraceLevels -- TRC_AVRC I/ ( 802): BTE_InitTraceLevels -- TRC_A2D I/ ( 802): BTE_InitTraceLevels -- TRC_BNEP I/ ( 802): BTE_InitTraceLevels -- TRC_BTM I/ ( 802): BTE_InitTraceLevels -- TRC_PAN I/ ( 802): BTE_InitTraceLevels -- TRC_SDP I/ ( 802): BTE_InitTraceLevels -- TRC_BTAPP I/ ( 802): BTE_InitTraceLevels -- TRC_BTIF E/bt-btif ( 802): Calling BTA_HhEnable E/bt-btif ( 802): ## btif_config_get assert section && *section && key && *key && name && *name && bytes && type failed at line:182 ## E/bt-btif ( 802): btif_storage_get_adapter_property service_mask:0x140040 D/BluetoothManagerService( 364): Bluetooth Adapter name changed to ABC D/BluetoothManagerService( 364): Stored Bluetooth name: ABC D/bt_vendor( 802): op for 2 I/bt_hwcfg( 802): SCO PCM configure {0, 1, 0, 0, 0} D/bt_vendor( 802): op for 6 D/ ( 802): bta_pan_co_init I/bte_conf( 802): Attempt to load did conf from /etc/bluetooth/bt_did.conf I/bte_conf( 802): [1] primary_record=1 vendor_id=0x000F vendor_id_source=0x0001 product_id=0x1200 version=0x1436 I/bte_conf( 802): Attempt to load did conf from /etc/bluetooth/bt_did.conf I/bte_conf( 802): Attempt to load did conf from /etc/bluetooth/bt_did.conf E/bt-btif ( 802): ## btif_config_get assert section && *section && key && *key && name && *name && bytes && type failed at line:182 ## D/BluetoothAdapterProperties( 802): ScanMode = 20 D/BluetoothAdapterProperties( 802): State = 11 D/BluetoothPanServiceJni( 802): control_state_callback(L61): state:0, local_role:0, ifname:bt-pan D/BluetoothAdapterService( 802): Broadcasting updateAdapterState() to 1 receivers. D/bt_vendor( 802): op for 7 D/bt_upio ( 802): proc btwrite assertion D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothManagerService( 364): Message: MESSAGE_BLUETOOTH_STATE_CHANGE D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothAdapterService(1109812520)( 802): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@4228f650 D/BluetoothManagerService( 364): MESSAGE_BLUETOOTH_STATE_CHANGE: prevState = 11, newState=12 D/BluetoothManagerService( 364): Broadcasting onBluetoothStateChange(true) to 9 receivers. D/BluetoothHeadset( 703): onBluetoothStateChange: up=true D/BluetoothInputDevice( 703): onBluetoothStateChange: up=true D/BluetoothAdapterService(1109812520)( 802): Get Bonded Devices being called D/BluetoothHeadset( 703): Proxy object connected D/HeadsetProfile( 703): Bluetooth service connected D/BluetoothAdapterService(1109812520)( 802): Get Bonded Devices being called D/BluetoothAdapterService(1109812520)( 802): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@4228f650 D/BluetoothPbap( 703): onBluetoothStateChange: up=true D/BluetoothInputDevice( 703): Proxy object connected D/HidProfile( 703): Bluetooth service connected D/BluetoothA2dp( 364): onBluetoothStateChange: up=true W/ContextImpl( 703): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1415 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothHeadset$1.onBluetoothStateChange:244 android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact:55 android.os.Binder.execTransact:351 W/ContextImpl( 703): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1415 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothInputDevice$1.onBluetoothStateChange:209 android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact:55 android.os.Binder.execTransact:351 W/ContextImpl( 703): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1415 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothPbap$1.onBluetoothStateChange:132 android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact:55 android.os.Binder.execTransact:351 W/ContextImpl( 364): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1415 android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange:131 com.android.server.BluetoothManagerService.sendBluetoothStateCallback:575 com.android.server.BluetoothManagerService.bluetoothStateChangeHandler:1189 com.android.server.BluetoothManagerService.access$3000:47 D/BluetoothHeadset( 364): onBluetoothStateChange: up=true D/BluetoothA2dp( 364): Proxy object connected D/BluetoothAdapterService(1109812520)( 802): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@4228f650 D/BluetoothHeadset( 546): onBluetoothStateChange: up=true D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothHeadset( 364): Proxy object connected D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothAdapterService(1109812520)( 802): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@4228f650 D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already E/bt_h4 ( 802): vendor lib postload completed D/BluetoothHeadset( 546): Proxy object connected D/BluetoothPan( 703): onBluetoothStateChange(on) call bindService W/ContextImpl( 364): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1415 android.bluetooth.BluetoothHeadset$1.onBluetoothStateChange:244 com.android.server.BluetoothManagerService.sendBluetoothStateCallback:575 com.android.server.BluetoothManagerService.bluetoothStateChangeHandler:1189 com.android.server.BluetoothManagerService.access$3000:47 W/ContextImpl( 703): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1415 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothPan$1.onBluetoothStateChange:173 android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact:55 android.os.Binder.execTransact:351 D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothPan( 703): BluetoothPan(), bindService called D/BluetoothPan( 703): BluetoothPAN Proxy object connected D/PanProfile( 703): Bluetooth service connected D/BluetoothHeadset( 546): onBluetoothStateChange: up=true D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothHeadset( 546): Proxy object connected D/BluetoothA2dp( 703): onBluetoothStateChange: up=true D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/CallNotifier( 546): - Got BluetoothHeadset: android.bluetooth.BluetoothHeadset@4223eba0 W/ContextImpl( 703): Calling a method in the system process without a qualified user: android.app.ContextImpl.bindService:1415 android.content.ContextWrapper.bindService:473 android.bluetooth.BluetoothA2dp$1.onBluetoothStateChange:131 android.bluetooth.IBluetoothStateChangeCallback$Stub.onTransact:55 android.os.Binder.execTransact:351 D/BluetoothA2dp( 703): Proxy object connected D/BluetoothManagerService( 364): Bluetooth State Change Intent: 11 -> 12 D/A2dpProfile( 703): Bluetooth service connected D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothAdapterService(1109812520)( 802): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@4228f650 D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothAdapterService(1109812520)( 802): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@4228f650 D/BluetoothAdapterService(1109812520)( 802): Get Bonded Devices being called D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothAdapterService(1109812520)( 802): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@4228f650 D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothAdapterService(1109812520)( 802): Get Bonded Devices being called D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already W/ContextImpl( 703): Calling a method in the system process without a qualified user: android.app.ContextImpl.startService:1361 android.content.ContextWrapper.startService:450 android.content.ContextWrapper.startService:450 com.android.settings.bluetooth.DockEventReceiver.beginStartingService:134 com.android.settings.bluetooth.DockEventReceiver.onReceive:115 D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/BluetoothAdapterService(1109812520)( 802): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@4228f650 D/BluetoothManagerService( 364): checkIfCallerIsForegroundUser: valid=true callingUser=0 foregroundUser=0 W/BluetoothAdapter( 802): getBluetoothService() called with no BluetoothManagerCallback E/BluetoothServiceJni( 802): SOCK FLAG = 1 *********************** D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already D/DockEventReceiver( 703): finishStartingService: stopping service D/BluetoothAdapterService(1109812520)( 802): getState(): mAdapterProperties: com.android.bluetooth.btservice.AdapterProperties@4228f650 D/dalvikvm( 364): GC_CONCURRENT freed 906K, 13% free 8034K/9136K, paused 3ms+7ms, total 84ms D/BluetoothPbap( 703): Proxy object connected D/PbapServerProfile( 703): Bluetooth service connected D/BluetoothManagerService( 364): checkIfCallerIsForegroundUser: valid=true callingUser=0 foregroundUser=0 W/BluetoothAdapter( 802): getBluetoothService() called with no BluetoothManagerCallback E/BluetoothServiceJni( 802): SOCK FLAG = 0 *********************** D/bt_vendor( 802): op for 7 D/bt_upio ( 802): BT_WAKE is asserted already I/BtOppRfcommListener( 802): Accept thread started. D/AudioHardware( 107): AudioHardware pcm playback is going to standby. I/alsa_mix( 107): -->Playback Path access 3 D/AudioHardware( 107): closePcmOut_l() mPcmOpenCnt: 1 D/bt_vendor( 802): op for 7 E/Lights ( 364): write_int failed to open sys/class/leds/battery_led/brightness D/bt_upio ( 802): ..proc_btwrite_timeout.. I/AudioService( 364): AudioFocus abandonAudioFocus() from android.media.AudioManager@42243eb8com.android.music.MediaPlaybackService$3@42242aa8 I/ActivityManager( 364): Start proc com.android.musicfx for broadcast com.android.musicfx/.ControlPanelReceiver: pid=1320 uid=10023 gids={50023, 3003, 3002, 1028} V/MusicFXControlPanelReceiver( 1320): onReceive V/MusicFXControlPanelReceiver( 1320): Action: android.media.action.CLOSE_AUDIO_EFFECT_CONTROL_SESSION V/MusicFXControlPanelReceiver( 1320): Package name: com.android.music V/MusicFXControlPanelReceiver( 1320): Audio session: 8 V/MusicFXControlPanelEffect( 1320): closeSession(android.app.ReceiverRestrictedContext@4223a0c0, com.android.music, 8) I/ActivityManager( 364): No longer want com.android.music (pid 858): empty #17 5. 开机静态LOGO的制作 取一张和屏幕分辨率一样的bmp或者png格式图片(其他格式应该也可以),用GIMP图片编辑器打开,在图像->模式->索引中,将最大颜色数量由256改成224,然后点击“转换”进行转换,接着 文件->导出,选择文件类型为ppm格式,然后导出,接着弹出的对话框选择ASCII码保存,即可生成ppm格式图片; 进入kernel/driver/video/logo中,找到logo_linux_clut224.ppm和logo_linux_clut224.c文件删除,刚才制作的图片重命名为logo_linux_clut224.ppm,然后编译kernel即可 注意生成的ppm图片比较大,但是编译出来的kernel是很小的。 全志平台第一张开机logo制作又不一样: 首先用ps打开bmp logo,在右边点击“通道”,如果显示的不是RGB,而是索引;那么在菜单 图像->模式中选择RGB颜色。这时候再看“通道”就可以显示RGB 红绿蓝图层了,但是还不行,点击”通道“旁边的按钮选择”新建通道“ ,默认名字alpha 1通道即可,这样红绿蓝图层后就多了一个alpha 1图层,将图片另存为bmp格式即可 编译RK4.2.2错误解决方法: Copying: out/target/common/obj/APPS/ContactsProvider_intermediates/emma_out/lib/classes-jarjar.jar 错误:读取 out/target/common/obj/JAVA_LIBRARIES/core-tests_intermediates/javalib.jar 时出错;invalid header field 1 错误 Copying: out/target/common/obj/JAVA_LIBRARIES/android.test.runner_intermediates/noproguard.classes.dex make: *** [out/target/common/obj/APPS/KeyChainTests_intermediates/classes-full-debug.jar] 错误 41 make: *** 正在等待未完成的任务.... 解决: $ cd out/target/common/obj/JAVA_LIBRARIES/core-tests_intermediates/ $ rm javalib.jar classes-full-debug.jar $ sudo update-alternatives --config jar 有 2 个候选项可用于替换 jar (提供 /usr/bin/jar)。 选择 路径 优先级 状态 ------------------------------------------------------------ * 0 /usr/bin/fastjar 100 自动模式 1 /usr/bin/fastjar 100 手动模式 2 /usr/lib/jvm/java-6-sun/bin/jar 63 手动模式 要维持当前值 update-alternatives: using /usr/lib/jvm/java-6-sun/bin/jar to provide /usr/bin/jar (jar) in 手动模式 $ croot $ make -j4 完毕! RK system.img 的打包方法: ./out/host/linux-x86/bin/make_ext4fs -s -l 536870912 -a system out/target/product/rk30sdk/obj/PACKAGING/systemimage_intermediates/system.img out/target/product/rk30sdk/system RK lcd参数配置: 新曾一个LCD,在kernel/drivers/video/rockchip/screen中增加一个文件如lcd_ZS070IH5030B3H7.c,lcd.h是自动生成的,具体看Makefile文件 其中一些参数的意义: #define OUT_FORMAT LVDS_8BIT_2 #define OUT_FACE OUT_P888//OUT_D888_P666 #define OUT_CLK 65000000 // LCD _DCLK #define LCDC_ACLK 500000000//312000000 //29 lcdc axi DMA 频率 /* Timing */ #define H_PW 10 //同步信号宽度 #define H_BP 150//160 //同步信号后消隐 #define H_VD 1024 //可视区域 #define H_FP 160 //同步信号前清隐 #define V_PW 10 #define V_BP 13//25 #define V_VD 768 #define V_FP 15 #define LCD_WIDTH 162 //LCD可视区域物理宽度(mm) #define LCD_HEIGHT 121 //LCD可视区域物理高度(mm) ... #define S_DCLK_POL 0 //双屏时 DCLK反向 /* Other */ #define DCLK_POL 0 // LCD DCLK 反向 #define SWAP_RB 0 // LCD 红绿颜色交换 调试scaler参数(lcd上显示有横线等时序出错的现象) cd ./sys/devices/platform/rk29_i2c.1/i2c-1/1--40/ catreg_ctl 屏驱动中的S_V_ST={reg[0x14],reg[13]}; echo13xx>reg_ctl(向0x13寄存器写入值xx); echo14xx>reg_ctl(向0x14寄存器写入值xx) RGB屏定义: #defineOUT_TYPE SCREEN_RGB LVDS屏定义: #defineOUT_TYPE SCREEN_LVDS //LVDS屏要配成SCREEN_LVDS #defineOUT_FORMAT LVDS_8BIT_2 //LVDS的接线方式 Scaler时钟反向: #defineDCLK_POL 0 //bypass显示时,画面抖动,可以尝试将这个取反 #defineS_DCLK_POL 0 //当双屏显示画面抖动时,可以尝试将这个取反 查看/sys/class/hdmi/hdmi-0/state /sys/class/hdmi/hdmi-0/enable 发现屏的显示有问题,先查一下外围环境是否正常。再作软件调节: 解锁屏闪、开机屏闪,可以延时一下背光。 屏闪、屏抖,可以修改一下帧率,时序。 clk = v_tal * h_tal * m hz 延时可以调时序,也可以避免不稳定的信号。 有些屏,每次初始化都会关背光,可能跟屏有关。 有些屏,供电过低,会导致上电时白屏,可以调节一下电压。 RK3026 android4.2修改kernel logo: #pngtopnm logo_linux_clut224.png>logo_linux.pnm #pnmquant 224 logo_linux.pnm > logo_linux_224.pnm #pnmtoplainpnm logo_linux_224.pnm>logo_linux_clut224.ppm RK3126 android4.4.4/RK3288 5.1的调试问题: kernel启动logo的制作,用PS制作bmp图片时候要在菜单 图像->模式中选索引颜色,弹出的确定用默认值即可,保存时候选window和8位 否则制作出来的logo混乱; recovery和充电logo转了180度,修改device中BOARD_HAS_FLIPPED_SCREEN即可,不过记得要进到bootable/recovery/minui中去mm -B;然后到bootable/recovery/中 mm -B,否则不生效啊 RK g-sensor方向调试: 最好的办法是在上报ABS_X,ABS_Y,ABS_Z中打印出上报的xyz三个值,把平板平放桌面上,xy值接近或等于0,z接近98000; y轴竖起与桌面垂直,xz接近0,y接近98000;x轴竖起与桌面垂直,yz接近0,X接近98000; 一般要修改的地方:xyz为负数,上报时候加上-号即可;xy对调了,那么ABS_X上报y的值,ABS_Y上报x的值即可。 |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1483 浏览 0 评论
1609 浏览 1 评论
1292 浏览 1 评论
2627 浏览 1 评论
3812 浏览 1 评论
GMT+8, 2025-1-4 11:07 , Processed in 0.552704 second(s), Total 72, Slave 56 queries .
