单片机学习小组
李伟
7年用户 1554经验值
如何去实现一种基于单片机CT107D的矩阵键盘扫描设计呢
如何去实现一种基于单片机CT107D的矩阵键盘扫描设计呢?
回帖(1)
李思路
2022-2-25 10:04:53
#include
sfr P4 = 0xC0;     //reg52.h 头文件里没有P4口的定义,如果要使用,需要自己添加
***it R1 = P3^0;           //定义矩阵键盘的行
***it R2 = P3^1;
***it R3 = P3^2;
***it R4 = P3^3;
***it C1 = P4^4;           //定义矩阵键盘的列
***it C2 = P4^2;
***it C3 = P3^5;
***it C4 = P3^4;
unsigned char count = 0;   //计数
unsigned char code SEG_code[18] =
        {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
         0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,
         0xbf,0x7f};            //定义共阳数码管段码内容:0~F,—,.
void Delay_keys()            //延时去抖动
        unsigned char i = 108,j = 145;
        while(--i)
                while(--j);
void Select_HC138(unsigned char n)
        switch(n)
                case 5:
                        P2 = (P2 & 0x1f) | 0xa0;
                        break;
                case 6:
                        P2 = (P2 & 0x1f) | 0xc0;
                        break;
                case 7:
                        P2 = (P2 & 0x1f) | 0xe0;
                        break;
void Show_tube(unsigned char value)
        Select_HC138(6);
        P0 = 0x01;
        Select_HC138(7);
        P0 = value;
void Scan_keys()
        C1 = C2 = C3 = C4 = 1;
        if(C1 == 0)
                Delay_keys();
                if(C1 == 0)
                        Show_tube(SEG_code[count+0]);
                while(C1 == 0);
        else if(C2 == 0)
                Delay_keys();
                if(C2 == 0)
                        Show_tube(SEG_code[count+1]);
                while(C2 == 0);
        else if(C3 == 0)
                Delay_keys();
                if(C3 == 0)
                        Show_tube(SEG_code[count+2]);
                while(C3 == 0);
        else if(C4 == 0)
                Delay_keys();
                if(C4 == 0)
                        Show_tube(SEG_code[count+3]);
                while(C4 == 0);
void main()
        Select_HC138(5);
        P0 = 0x00;                 //关闭蜂鸣器和继电器
        P3 = 0x0fe;             //R1 = 0;
        while(1)
                Scan_keys();
        //x是要循环左移的目标数据,y是变量x的位数,z是期望循环左移的位数:x = (x >> (y-z)) | (x << z);
                P3 = (P3 >> 7)| (P3 << 1);    //将0循环左移一位,依次将R2、R3、R4置为0
                count += 4;
                if(count > 12)
                        P3 = 0xfe;
                        count = 0;
