Platform: Rockchip
OS: Android 6.0 Kernel: 3.10.92 ,这里看一下它的移除过程是怎样的,当选择界面的FORGET时,会触发以下流程调用。 onForget -> forget -> mWifiManager.forget -> WiFiSettings.java //参数为当前选择forget的config的netid sAsyncChannel.sendMessage -> 异步通道发送给WifiStateMachine,cmd是FORGET_NETWORK processMessage -> WifiStateMachine.java //当前处于ConnectedState,调用父类的父类ConnectModeState mWifiConfigStore.getWifiConfiguration //根据netid得到对应的config mWifiConfigStore.canModifyNetwork //检查调用者是否有权限remove network mWifiConfigStore.forgetNetwork -> removeConfigAndSendBroadcastIfNeeded -> //执行清理操作 mConfiguredNetworks.remove //从ConfiguredNetworks中移除 mScanDetailCaches.remove sendConfiguredNetworksChangedBroadcast //发广播wifi状态变化: WifiManager.CONFIGURED_NETWORKS_CHANGED_ACTION mWifiNative.removeNetwork -> doBooleanCommand //通知WPAS移除network,命令是"REMOVE_NETWORK " + netId,这和用wpa_cli客户端的方法是一样的 mWifiNative.saveConfig -> doBooleanCommand //通知WPAS更新配置文件wpa_supplicant.conf handleEvent WifiMonitor.java -> WPAS移除完毕之后会发DISCONNECTED事件过来,由WifiMonitor负责接收 handleNetworkStateChange -> notifyNetworkStateChange -> mStateMachine.sendMessage -> //NETWORK_DISCONNECTION_EVENT, 发给WifiStateMachine processMessage -> //ConnectedState dispatchEvent -> 接着WifiMonitor又收到WPAS发来的STATE_CHANGE事件 handleSupplicantStateChange -> notifySupplicantStateChange -> // mStateMachine.sendMessage -> //SUPPLICANT_STATE_CHANGE_EVENT processMessage -> //当前处于ConnectedState,调用父类的父类ConnectModeState handleNetworkDisconnect -> stopRssiMonitoringOffload -> //通知HAL stop rssi mWifiNative.stopRssiMonitoring -> stopRssiMonitoringNative -> android_net_wifi_stop_rssi_monitoring_native -> hal_fn.wifi_stop_rssi_monitoring clearCurrentConfigBSSID -> //清理bssid clearConfigBSSID stopDhcp -> //关dchp,之前有分析过startdhcp的 handlePostDhcpSetup mDhcpStateMachine.sendMessage //DhcpStateMachine.CMD_STOP_DHCP processMessage -> //DhcpBoundState processMessage -> //DhcpHaveAddressState的父类DhcpState transitionTo(mStoppedState) -> exit -> //DhcpHaveAddressState setIpAddress -> mNMService.setInterfaceConfig //通知netd设置ip mNwService.clearInterfaceAddresses mNwService.disableIpv6 setNetworkDetailedState //这部分和ConnectionService有关,打算后面再细讲 mNetworkAgent.sendNetworkInfo sendNetworkStateChangeBroadcast //广播WifiManager.NETWORK_STATE_CHANGED_ACTION transitionTo(mDisconnectedState) -> exit -> //ConnectedState setScanAlarm //关闭周期性scan enter -> //DisconnectedState startScan //断开连接后进入定期扫描 |
迅为RK3588开发板实时系统编译-Preemption系统/ Xenomai系统编译-实时系统测试-Preemption测试
631 浏览 0 评论
【幸狐Omni3576边缘计算套件试用体验】开发板基础体验:大模型和推流测试
422 浏览 0 评论
【幸狐Omni3576边缘计算套件试用体验】Debian系统安装和性能测试
780 浏览 0 评论
555 浏览 0 评论
1601 浏览 3 评论
GMT+8, 2025-3-14 21:24 , Processed in 1.263857 second(s), Total 70, Slave 54 queries .
