本威廉希尔官方网站
的打火机制是利用电容器在跨越初级线圈时发生放电现象,在点火线圈上产生火花。
The CDI ignition circuit produces a spark from an ignition coil by discharging a capacitor across the primary of the coil. A 2uF capacitor is charged to about 340 volts and the discharge is controlled by an SCR. A Schmitt trigger oscillator (74C14) and MOSFET (IRF510) are used to drive the low voltage side of a small (120/12 volt) power transformer and a voltage doubler arrangement is used on the high voltage side to increase the capacitor voltage to about 340 volts. A similar Schmitt trigger oscillator is used to trigger the SCR about 4 times per second. The power supply is gated off during the discharge time so that the SCR will stop conducting and return to it's blocking state. The diode connected from the 3904 to pin 9 of the 74C14 causes the power supply oscillator to stop during discharge time. The circuit draws only about 200 milliamps from a 12 volt source and delivers almost twice the normal energy of a conventional ignition circuit. High voltage from the coil is about 10KV using a 3/8 inch spark gap at normal air temperature and pressure. Spark rate can be increased to possibly 10 Hertz without losing much spark intensity, but is limited by the low frequency power transformer and duty cycle of the oscillator. For faster spark rates, a higher frequency and lower impedance supply would be required. Note that the ignition coil is not grounded and presents a shock hazard on all of it's terminals. Use CAUTION when operating the circuit. An alternate method of connecting the coil is to ground the (-) terminal and relocate the capacitor between the cathode of the rectifier diode and the positive coil terminal. The SCR is then placed between ground and the +340 volt side of the capacitor. This reduces the shock hazard and is the usual configuration in automotive applications. |
2 个讨论
本威廉希尔官方网站
一个晶闸管控制的2微法的电容器大约能充放出340V电压。一个施密特触发振荡器(74 C14)和MOSFET(IRF510)用于驱动低压端的一个小型(120/12V)电源变压器,a voltage doubler arrangement 用于在高压端提供给电容器340V电压。施密特触发振荡器提供SCR每秒4次的触发。当电容放电的时候SCR停止执行并返回截止状态,从而电源关闭。74 C14的第9引脚与3904通过二极管连接起来,从而使电源振荡器在放电状态过程中停止。 |
GMT+8, 2025-1-4 16:07 , Processed in 0.667462 second(s), Total 42, Slave 33 queries .
