Error: Failed to read priv register.
Warn : Failed to read memory via abstract access. Error: Target riscv.cpu.0: Failed to read memory (addr=0x200000e4) Error:? ?progbuf=skipped (target not halted), sysbus=skipped (unsupported size), abstract=failed Error: Failed to read priv register. Error: Target riscv.cpu.0: Failed to read memory (addr=0x200000e5) Error:? ?progbuf=skipped (target not halted), sysbus=skipped (unsupported size), abstract=failed Error: Failed to read priv register. Error: Target riscv.cpu.0: Failed to read memory (addr=0x200000e6) Error:? ?progbuf=skipped (target not halted), sysbus=skipped (unsupported size), abstract=failed Error: Failed to read priv register. Error: Target riscv.cpu.0: Failed to read memory (addr=0x200000e7) Error:? ?progbuf=skipped (target not halted), sysbus=skipped (unsupported size), abstract=failed Error: Failed to read priv register. Error: Target riscv.cpu.0: Failed to read memory (addr=0x200000e8) Error:? ?progbuf=skipped (target not halted), sysbus=skipped (unsupported size), abstract=failed Error: Failed to read priv register. Error: Target riscv.cpu.0: Failed to read memory (addr=0x200000ea) Error:? ?progbuf=skipped (target not halted), sysbus=skipped (unsupported size), abstract=failed 你好,这个是什么问题?单片机型号是:CH32V203F6P6 同样是V182版本,两台电脑,一台让我切换到2.6,一台让我切换到2.7 |
您好,该问题可能是芯片读保护开启了导致的,可关闭读保护后再次调试。MRS V182在安装最新的芯片开发组件(计算机联网后会获取组件更新推送,支持自动下载安装)后即可使用V2. 7版本WCH-Link固件。
534 浏览 1 评论
CH579M+RT-Thread,RTC从Sleep模式唤醒失败是什么原因?
2910 浏览 2 评论
2404 浏览 1 评论
880浏览 2评论
695浏览 1评论
riscv-none-embed-objcopy: \'PWM_Output.elf\': No such file这个咋解决,
423浏览 1评论
540浏览 1评论
请教一下,Mounriver 编译不成功:找不到库文件,怎么整
821浏览 1评论
GMT+8, 2024-12-29 12:39 , Processed in 1.118961 second(s), Total 79, Slave 62 queries .
